Question about Gigabyte Computers & Internet
Power keeps turning off and it beeps then shutdown
I'm looking for the manual and the wiring setup
  • 70 Answers
You don't state which gigabyte board you are using but if you go to thier site
http://www.gigabyte.com.tw/Support/Motherboard/Driver_List.aspx
you can input your particular mobo model# and dload the manual and any drivers you may need.
Good luck
Sean
Posted on Mar 12, 2009
Pc keeps turning on and off
There's a lot of reason why the computer keeps turning on and off. The following are the common factors -
1. Driver Issue - common symptom is BSOD (Blue Screen of Death) before shutdown. Get the error code that usually starts in 0x12345abc. Unplug any newly installed hardware or any usb device then check. If unsuccessful, boot to safe mode and if computer behaves normally then isolate the problem by performing a clean boot.
How to perform clean boot in Windows
Start your computer in safe mode Microsoft Windows Help
2. Defective internal components such as motherboard, memory module, video card.
- Simplest way to check for motherboard issue is check the computer time. If it keeps on changing then probably a busted battery that needs to be replaced in the motherboard. If not, have it serviced by a local tech or reputable computer shop.
- Perform memory test that is built-in to the motherboard. If the memory is defective, either clean it using a pencil eraser or have it serviced.
- Listen for "beep sounds" before startup. This should give you an idea of what the problem is.
Computer POST and beep codes
3. Insufficient Power / Overheating.
- check the voltage of your power supply and if it is still sufficient enough to supply the motherboard. Check the temperature, if the fan speed is sufficient to cool down the processor. Download the software to check everything.
CPU CPUID System hardware benchmark monitoring reporting
4. Due to Viruses/Malwares
- perform the abort shutdown command to prevent the computer from turning off. go to start - run - type shutdown -i
5. If you are not comfortable doing all this, go to the nearest computer shop. Hope this helps.
Jul 09, 2014 | Computers & Internet
Tv just turn off during use.
You may be having problems with your overcurrent shutdown circuit. This circuit shuts down you high voltage power supply due to components drawing excessive current, If you do not have electronics experience I would suggest taking the set to a repair shop.
Sep 24, 2007 | Panasonic PT-52LCX65 44" HDTV
My freeview digital tv recorder model ferguson f20320dtr keeps switching off without being turned off
It perhaps has somekind of automatic shutdown when not in use. It should have a way to turn this off. Look around the menu system, it might come under power options etc. Or look in the manual for auto power functions.
May 27, 2014 | RCA VR525 VCR
Why does my dimension 8200 dell desktop say "strike f1 to retry boot, f2 for setup utility"
Rduy Cruz,
This error message references that your system Primary hard drive is not being Detected in the system. You can press F2 to enter the setup to see if the hard drive is even being seen. If not, exit out and shutdown the system. Unplug the power cable and open the computer to reseat the hard drive cables at the hard drive and at the motherboard connection. If that does not resolve the issue you may need to replace the hard drive IDE cable.If all this does not work you may need to replace the hard drive. Please post back if this does not resolve the issue.Below is a link to your online manual for your computer.
Dimension 8200 Online Manual
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 24, 2013 | Dell Dimension 8200 PC Desktop
My compaq sr1103wm will not power up. Whan you turn it on it starts to boot for about 5 seconds. It just keeps turning on and off on and off on its own. Could this be a power supply problem or...
It could be "sort of" either. If the power supply fan is labouring or stopped, it will overheat very quickly and force a shutdown or blow a fuse. Because of the latter usually this will only happen a few times, and then perminently. If the cpu fan bushings are clogged with jam, and it is labouring, the cpu temps will shoot up and trigger a bios level shutdown. So you need to do some checking, and perhaps some cleaning. Usually if there are motherboard problems, you will get beeping indications of device checks. If there is no picture, then the vga card could be loose...but again, beeping for sure. loose power cord connect or worn - problems, not always a beep here. Check a cables and connections but the first checks are likely the root.
Jun 13, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
It shows error code 80010006 when i try to load a game
Hi ctslim,
80010006 - An error occurred during the start operation. - Corrupted folding install.
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up
I'll post another message as I keep being told Im exceeding my maximum text limit...
Feb 23, 2011 | Sony Playstation 3 (PS3) Console
My ps3 keeps logging me out and during play it freezes up, I also have a corrupted data file that it wont let me delete
1. Turn off Playstation 3. 2. Hold the power button down; the system will turn on and turn off once again. 3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps 4. When you hear the 2 beeps take finger off power button. 5. You will be prompted to plug in your controller via USB and then hit the PS button 6. The Recovery menu will pop up. 7. Select "Restore File System" from the Recovery menu. 8. Agree to restoring the file system.
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
My Hitachi Keeps Turning Off
sir i think theres something wrong with the power supply kindly check it out,,,thankss and hope too help you,,gud luck
Feb 26, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Motorola MD4260
I had the same problem.
Here is the solution that I received from Motorola tech support:
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
Nov 22, 2007 | Motorola Mobility MD4260-2 Twin Cordless...
Computers & Internet Logo
98 people viewed this question
Top Gigabyte Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
