Question about Dehumidifiers
Fedders dehumidifier model FDG50GA compresser never starts.
The fan runs and I hear a click like a relay sound then off fan still running and the click again, this cycle continues. but the compressor never comes on. Could it be the compassador (sp.) ??
Of course it never collects water, this unit has worked a lot in a damp basement for the past 2-3 years. Its has been cleaned .
Thank you for any suggestions..
Stan
techman
  • 3130 Answers
SOURCE: Dehumidifier Compressor is not working
this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at customerservice@delonghiusa.info Good Luck
Posted on May 31, 2006
  • 883 Answers
SOURCE: dehumidifier
if the fins feel cold then you should be collecting condensate. so try this: remove the outer shell to access the fins. with a garden hose, spray the fins off thoroughly. you may see a lot of dust and line that was clogging the air flow.
Posted on Jun 03, 2007
  • 184 Answers
SOURCE: Fedders Dehumidifier
ALL DEHUMIDIFIERS REQUIRE ROOM TEMPS TO BE AT LEAST 65 DEGREES AND A HUMIDITY OF AT LEAST 50 % TO OPERATE PROPERLY. ANYTHING LESS AND IT MAY FREEZE THE EVAPORATOR COILS. EVAPORATOR COILS WILL ALSO FREEZE IF THE COILS ARE DIRTY AND HAVE RESTRICTED AIR FLOW.TRY TAKING THE COVER OFF OF THE UNIT AND CLEANING BOTH SETS OF COILS INSIDE. THEY ARE COPPER OR ALUMINUM WITH FINS ON THEM.
ALSO CHECK THE FAN TO BE SURE IT IS RUNNING.
THAT WILL CAUSE AN OVERHEATING CONDITION AND WILL SHUT DOWN THE COMPRESSOR ALSO.
Posted on Apr 08, 2008
  • 1462 Answers
SOURCE: Oil inside the water collection res
the compressor runs in oil. suspect you have a quite bad leak and loss all the gas - hence no water collection and the compressor oil is being pumped out thro the leak
Posted on Jun 26, 2008
  • 121 Answers
SOURCE: Dehumidifier runs but does not condense water.
It sounds like an issue with the control bord. This dehumidifier should have a 5 year warranty through LG. You will need to have this serviced. If it is under warranty by LG they will either refer you to a local repair shop and they will pay for the repair or they will replace it if you do not have a repair shop in your area. Call them and explain the problem to them. Make sure that you have your reciept. Here is the contact information for LG:
Toll Free Phone Number: 1-800-243-0000
Email: customerservice@lge.com
Keep me posted. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Posted on Jul 08, 2008
Fedders a7dh45b2a powers on fan does not run, all othr lights are on anyone have any suggestions
on this model i suspect that bucket sensor is saying bucket is full if not true then adjust bucket sensor piviot
Oct 10, 2014 | Fedders Dehumidifiers
Turns on but fan and compresser does not run
start relay on compressor fans will not work if pumps not running
Nov 16, 2013 | Winix WDH751 Dehumidifier
Compressor won't start,can hear circuit breaker clicking out. Fan runs okay,gauges reading okay.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 06, 2011 | Fedders A7DH45B2A Dehumidifier
Doesn't dehumidify
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 01, 2010 | Fedders A7DH45B2A Dehumidifier
I have a dehumidifier that runs but does not pull moisture from the air in the basement. the application is about 3-5 years old. It is a Maytag and I purchased it at Home Depot. The Model is M3DG30B2A A....
There are a couple of things you can check for and they are; First of all, when you say the unit is running you may only be hearing the fan run. The compressor may possibly be not running(if it isn't running you will have no dehumidification as a dehumidifier is really nothing more than a small airconditioner.(cooling a coil for the moisture in the space to condense to). Second, The space may be to cool for the unit to run and dehumidify well, The space should at least be 65 degrees or warmer. Third, the system may have a leak and it is out of or low on refrigerant(freon). Depending on what you paid for the unit and if it has any remaining warranty(parts only-labor not covered) if the system is out of refrigerant or if the compressor is bad it probably isn't worth the cost to repair.
Nov 09, 2009 | Fedders A7DH65B2A Dehumidifier
The coils are freexing up. How can i fix this? fedders dehumidifier a7dh45b2a
Make sure your coils are clean and free of restrictions and that the fan is running. If this is ok, then it is probably a leak in the system resulting in low charge. Cost of new dehumidifier will be cheaper than having it repaired.
Oct 03, 2009 | Fedders A7DH45B2A Dehumidifier
Dehumidifier not collecting moisture
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jan 31, 2009 | Kenmore 54501 Dehumidifier
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Dehumidifiers Logo
189 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
