Question about Sony KP-53V75 53" Rear Projection Television
Sony KP-53V75 picture problem
My wife was watching it and something went POP and the picture now has a big bow in the bottom of it about 30-40% up from the bottom. CNN ticker has three separate lines in colors red-blue-green that are bowed up from the bottom.
I had the same "Bowed 3D" issue.
I found the problem to be a couple of bad solders on the board. the big black IC's that have heat sinks attached to them had over time developed cracks on the boards from heat, and I also after looking found a couple of other bad solders in various places. I re-soldered anything that looked bad or that I thought could be a problem. TV works fine now. I had symptoms leading up to this. Picture not as good, the 3D effect would happen but would stop when TV was hit on side at first, then 3D effect just stayed bad.
Posted on Jun 12, 2012
    Scholar:
  • 41 Answers
I'm sorry to say that Jean is off on this one. This sounds like a convergence issue and cannot be fixed with these knobs. If you set looks like the pictures shown most likely the STK chips (possibly other components) are blown as explained in Ecullier2012's posting. If the convergence went bad suddenly and or you cannot fix it with the convergence adjustments on the set, most likely that is the problem. If it moved slightly out over time then most likely you will be able to fix it through the convergence menu on the set. Many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present and they can reside even when the set is unplugged. I also have a posting about the STK chips in another section that may help explain this issue. The link Jean posted is for a specific issue that is common on some Sony sets, and should not be used unless you know for sure that is your issue. I also have a posting about this.
Posted on Mar 13, 2009
  • Sony Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. ThisSony KP-53V75 picture problem - 2c07611.pngn problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Hope the blog helps you also :)
Jean
Posted on Mar 12, 2009
My sony kp 53v75 projection tv has an issue right now. The screen has lines that run horizontally across the screen that slightly distort the image. They move up and down slowly on the screen, Is there any...
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 22, 2010 | Sony KP-53V75 53" Rear Projection...
My sony color rear video projector tv has fuzzy picture & colors seem to un together
I think it something wrong with the convergence circuit, two STK ICs need to replace, the Generic part # like STK394-160E. you can check on the IC. The price approx $35.
Apr 28, 2010 | Sony KP-53V75 53" Rear Projection...
I have a Sony KP-53V75 projection tv and there is not color on the screen. All three color guns are functioning and the convergence works. Why am I not getting a color picture on the screen?
sounds like you are having problems with the luminance and chroma circuits.go into menu and check the settings. If they are ok, then you maybe making a trip a repair center
Sep 08, 2009 | Sony KP-53V75 53" Rear Projection...
Picture and writing in 3d
replaced both convergence ics.the red green and blue colors are not converging.these ics are two big black ics.
Jul 28, 2009 | Sony KP-53V75 53" Rear Projection...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
The green color seems to be out of place on my 53fdx01b projection television
I have a  SONY      MODEL #  KP-53V75  and th e pic is very faint, like the bulb has alot of dust on it or something , and there are some weird colors on the bottom? Any suggestions would be extremely appreciated!
Sep 14, 2008 | Televison & Video
I have a pic problem is it fixable
If the picture is bowing in on the sides, this is called a pincushion problem. Please confirm that your model is KP-53XBR45 and I'll look up the probable defective parts.
Dan
Aug 26, 2008 | Sony KP-53XBR45 53" Rear Projection...
Sony kp-53s35 bowed picture on top and bottom
Good day, scotty1980;
Scotty, welcome to 2008. Hold onto your wallet, the has a convergence problem. Which means that the TV's convergence IC's are more than likely bad. The average cost to repair is about $450.00. Unless you are electronically friendly, I would call an authorized service dealer for repair.
Good luck, big IRISH. PS; Hope this was helpful.
May 04, 2008 | Sony KP-53S35 53" Rear Projection...
Sony kp-46s4u
look in hte convergence circuit for opened reistors.
Oct 11, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KP-53V75 53" Rear Projection Television Logo
393 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
