Question about Marantz DV-6500 IN STOCK DVD Player
Marantz DV-6500 problem
Two days ago my Marantz universal DVD player stop working. The unit turns it off by itself 2 or 3 seconds after a disc is loaded. It tries to read the disc but then right after it stops spinning and turns it off. Open-close works flawlessly (the only thing that works right now. It just dont play any disc. Any clue?
  • 4 Answers
Could be the laser Try cleaning it and if not Try and get it repaired Unless you wan't to buy a new one
Posted on Aug 03, 2007
SOURCE:
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
Tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 | Televison & Video
Sony dvd player DVPCX995VMakes grinding noise and door won't open
I was able to fix this myself, however, I did get instructions from Sony that may or may not work. My solution was:
Unplug the unit and carefully (so the disks don't shift) move to a location where it can be easily worked on.
Remove the 9 screws holding the cover on. 2 on top, 2 on each side, and 3 at the back, along the top edge.
Carefully, may need some wiggly remove the cover. There are some rubber pads at the front of the unit that hinder the cover from sliding. Slightly wiggling and pulling to the rear will dislodge it.
Confirm all disks are properly aligned on the carousel.
Pull out any disks that are askew. They will be replaced later in the same way disks are added, through the door.
Look in the rear where the laser unit is.
Carefully slide out disks near the laser. You'll have to move some in order to tip others out.
By taking out 6-10 disks, you'll probably find there's one partially lodged in the laser unit. With adjacent disks removed you can slide the "stuck" disk out.
Plug in the unit and test to see if the grinding stopped.
Unplug the cord.
Replace the cover with the 9 screws. Some wiggly and pushing forward is needed to reseat the cover at the front.
Carefully move the unit back to where it was.
Replace cables and plug in.
Return the disks removed according to the instructions.
This took me about 15 minutes from start to finish.
The following was provided by Sony. I don't know if this works as I had fixed it before Sony responded.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons. NOTE: This step may not apply to all models. DISC1 is not available on all DVD players.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Oct 11, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Pioneer DV-400V. Worked fine a few hours ago and
Mine did the same a couple of days ago, I have taken in for repair, will get back once with details soon.
Sep 30, 2009 | Pioneer DV-400V DVD Player
Samsung dvd-v5600 is set on region 4
This code is for DVD-5500 and DVD-6500. It may work for DVD-5600 as well.
  1. Turn on the player (without a disc inserted)
  2. Press and hold PLAY and FW (or STOP)
  3. "No Disc" is displayed
  4. Release the keys
  5. Press SUBTITLE, REPEAT (or just SUBTITLE or just REPEAT or MENU)
  6. Enter the corresponding combination for your current RC (see top of the page)
  7. Current RC should be displayed
  8. Press the button for the desired RC (9=codefree)
  9. Open the disc tray
  10. Turn the player off
Apr 13, 2009 | Televison & Video
Marantz DV-4001 front display not working.
Unplug the AC ..Let it set for a few minutes. PLug it in.
If no display still , it may be the backlight for the display that's quit.
Let me know,
Scott
Mar 18, 2009 | Marantz DV4001 DVD Player
Problem with Marantz DV 7001 DVD player
i am not an expert, but I have read that it is important to make sure the Marantz is set to the same resolution to your tv. If not you will have blanks screens.
Let me know if it works. I just got one for my mom.
Mar 04, 2008 | Televison & Video
Marantz DV-6500 IN STOCK DVD Player Logo
294 people viewed this question
Top Marantz Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
