Question about Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White
How do I replace the 'inlet' washer on a 15/20 year old caroma Concorde system
Sometimes after flushing the water continues to flow
2 Suggested Answers
bloues
  • 56 Answers
SOURCE: I have an old Caroma Dual flush ( 15-20 years) and
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
Posted on Jul 12, 2010
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Where can I buy Caroma outlet seals?
Take the existing part to Lowes or Home Depot and look at there universal
toilet replacement parts. I bet you can find one that will fit.
Jan 04, 2013 | Caroma CARAVELLE270ADAW-EL Caravelle...
Error code nf
The nF error means that the washer isn't filling properly. Make sure that both the hot and cold water inlets are getting water flow. (You can get all cold water washes by connecting the hot to a second cold water line.) Make sure that you have opened the shut-off valves for both inlets to the washing machine. Check that there is sufficient water pressure on both inlets. You need 20-116 psi (pounds per square inch). Use the Samsung supply hoses. Some flood safe hoses may not work (even if new); when damaged, they can completely restrict the flow of water to the washer.
Take off the hoses. Check the filters both on the shut-off side and just inside the washer and clean then of any foreign objects. This is a good time to double check the water pressure at the shut-off valves (have a bucket under the valves.) Replace the inlet hoses if they are more than 5 years old.
Check that the drain hose is not lower than the water level in the washer. This can trigger suction causing the water to flow into the washer and straight out to the drain.
Make sure that the door of the washer is tightly closed. Then press the Start/Pause button.
If the error continues, the failure could be at the washer's inlet valve, the sensor that checks the weight of the drum + water, or the wiring or wiring harness to either one of these items. The computer control board can also fail to "hear and respond" to the above. If you have water in the drum with the nF error, start checking the sensor. If no water flows into the washer, check the valve first.
I hope this helps.
Oct 12, 2012 | Samsung WF337AA Front Load Washer
I have a Caroma Concorde Toilet the washer needs replacing where can I find one? I have no idea how old this toilet is
just pop in to any hardware shop ther all pretty much the same thing these days.
Dec 21, 2011 | Home
Despite fitting a new washer kit to an old style caroma dual flush/float system stop valve..water is still seeping into tank....even if i plug the inlet nozzle with my finger which yu would think would be...
I suppose you're talking about a toilet. One likely issue is the flapper valve ( if this has one). If no flapper then check whatever sealing mechanism is used to prevent water from entering the bowl when idle. Clean the sealing surfaces good. Make certain they are properly aligned.
Sep 01, 2017 | Caroma 270W-RF Reflection Round Front...
I have Duet front load washing machine and over the last 7-8 years have battled he FH code.I have opened the machine numerous times, tried to flush and back flush the water valves/solenoids gone back and...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an old Caroma Dual flush ( 15-20 years) and the washers on the inlet valve dont seem to be able to regualate the flow in, after the toilet has been flushed, as a result water sprays up out of the...
Plz rate my advice
Jun 16, 2010 | Caroma 270W-RF Reflection Round Front...
I have a 1998 Caroma Reflections cistern p/n 6871774. It is making a hissing noise after the tank is refilled, and water streaks down from the supply rim of the bowl. Which part needs to be replaced?
the inlet washer needs to be replaced to stop the overflow, the washers are easy to get and cheap but trying to get the unit open to replace the washer is my big question at the moment
Jan 10, 2010 | Caroma 270W-RF Reflection Round Front...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
Caroma 270W-RF  Reflection Round Front Dual Flush Toilet - White Logo
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
