Question about Whirlpool Duet GHW9150P Front Load Washer
Sounds like rocks in my front loading washing machine
I have a front loading washing machine Whirlpool duet it sounds like rocks in the washing machine there is nothing in the tub. Any idea what is wrong?
  • 3 more comments
  • Anonymous Mar 12, 2009
    no but mine does the same thing
  • Donna Quast Mar 14, 2009
    yes it was the problem, I found pennys in the drain pump.
    Thanks
  • jcdike Mar 27, 2009
    I have the same problem, too.
  • Anonymous Mar 16, 2014
    override auto load sensor whirlpool wtw57esvw washing machine
  • Anonymous Mar 29, 2014
    Recently my front-load wash machine (Whirlpool Duet) has started making horrible noise when it runs. It sounds like on old wash machine that has an unbalanced load in it. Then, it sounds like someone is knocking really loud.
    This isn't a simple, it's not balanced on the ground. I've already checked that.
    Do you have any clue what could be wrong?
    President:
  • Whirlpool Master
  • 2,651 Answers
Did you try removingthe lower acess panel and checkin g the drain pump for possible obstruction??
Posted on Mar 12, 2009
Washer will not drain. It sounds like the motor for the pump is running but nothing is coming out. Whirlpool Duet washer.
It sounds like you may have a kinked drain hose or an obstruction in the hose coming out of the tub to the pump. The pump filter screen may also be clogged.
Are you getting any error codes?
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
THE WHIRLPOOL DUET WILL SHAKE YOUR HOUSE APART DURING THE SPIN DRY CYCLE. WHAT CAN I DO?
Adjust your washer's front legs and lock the nut, it has another nut to do this. After you hav locked the legs, try to rock the washer with your hands, it should not rock. Another thing to check will be inside your washer, after taking the power off the wall socket. Check to see if some springs or the shocks (dampers) have come loose. This normally happens when the load is not even, that is when you hav a big sheet in one part of the washer tub. Spread out the clothes evenly before you commence the wash.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer sounds like a marble is loose
You washed something from your pockets. coins, marbles, I even removed a nail clipper before. Use a flashlight and try to look through the holes. If you can get front panel off. Put light under tub and see if you can see something that way.
Oct 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer rocks and will not stay put. Perfectly level
check to see if the shocks are broken, 4 of them. A service guy fixed mine with new ones
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leeks onto floor occasionally.
hello.
Welcome to Fixya.
  • nspect the water supply connections.
  • Inspect the drain hose.
  • Inspect the water pump.
  • Inspect outer tub for cracks or corrosion.
  • Inspect the tub seal.
  • Inspect the tub bearing.
Good Luck.
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a front load washing machine, model #ghw9100lw. It goes into the spin cycle and as the speed increases a very loud knocking sounds comes from the machine. I took the front top and lower front...
i had a similar problem, its more than likely that something is wrong with the metal basket inside, like a broken tripod leg on the back, or mine was missing 2 screws on one of the legs.
if you dont fix and soon you will have to get a new front outer tub. if its less than 10 years old it should be in warrenty and you can have a whirlpool repair man come fix it, you will just be responsible for the cost of service call and labor, which is around 300 in itsself.
if you decide to fix it your self the front outer tub is around 100, metal tub is around 200, and if you happen to break any of the shocks trying to get them off, they are 15 a piece at appliancezone.com.
Apr 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer has rock, marble, or something stuck inside
as long as your sure its an item between the tub assy the baffles in the drum can be removed and item fished out. but ifsomething snapped on the rear of the drum you would need to replace it. the baffle part number is 8182233, its about $40 thinknin thats worth a try before 475. the lower acess panel could also be removed and the main tub to pump hose could be removed which would give you a 3in hole to look through and try to grab somethin. worth a try
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
noisy may be the tub is hiting some thing. you can open the top of the washer and ck. it is very simple. sud are you using the he soap.
Feb 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
530 people viewed this question
Dan Webster
Dan Webster
Sal De
