How to turn off time delay on Home King DW1600
Blower fan stays on all the time .even when is shut the thermostat off.
On gas pack units, there is a hot box time delay switch that turns the fan on when the temperature is hot enough. I would think this switch is stuck to on, contacts closed. Find this switch and disconnect a wire from it with the power disconnected, then restore power to test, or sismply use a continuity tester across the switch.
May 20, 2015 | Weather King Heating & Cooling
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
Entry delay is set correct but I want it to call out more quickly when the alarm actually goes off. It seems to wait too long. Do the entry delay and the actual alarm call out delay always the same?
Installation manual is here:
http://www.sdilink.com/GE%20Manuals/Simon%203%20Install.pdf
Programming starts on page 17.
Dialer Delay is option 17 on page 29. It's default setting is 30 seconds.
To set Dialer Delay, press:
1.Add
2.Option #
3.17
4.Use the numbered keys to enter the time 005 -
254 seconds (all entries must be 3 digits).
5.DONE
To turn off Dialer Delay, press:
1.Delete
2.Option #
3.17
4.DONE
Hope this helps.
May 10, 2011 | GE Security Simon 3 Wireless Home Security...
Need to make entry time longer . I am able to delete option 10 but can't add option 10. Entry is only 5 sec.
Here is instructions from Installation Manual. I am also attaching links to full Installation as well as User Manuals for your reference at the bottom of page. Make certain to input as 3 digit time - example 45 seconds as 045. Good luck!
Option 10: Entry Delay (Default = 030 sec.)
Determines how much time the user has to disarm the system
after entering the armed premises through a designated delay
door, before an alarm occurs. Beeps sound during the entire
delay time to remind the user to disarm the system.
When turned on, the Entry Delay can be set from 005-254
seconds (030-254 if SIA Limits Option 69 is on). All entries
must be 3 digits. When turned off, the Entry Delay is set to
005 seconds.
Note
For UL listed systems, the entry delay must not exceed 45 seconds.
 To set Entry Delay, press:
1. Add
2. Option #
3. 10
4. Use the numbered keys to enter the 3-digit delay
time.
5. DONE
 To turn off Entry Delay, press:
1. Delete
2. Option #
3. 10
4. DONE
Installation - http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=334&prod_id=171
Users: http://www.safemart.com/manuals/simon3.pdf
Oct 02, 2010 | GE Security Simon 3 Wireless Home Security...
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
Air king problem
. You probably have too many time delays in your system and check the timer set points. sometime some thermostat has a time delay and the unit itself has a circuit board time delay.
Sep 02, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King split AC system.
Turn the power off ,and check all the electrical connections for loose connection or wires. also make sure these are slow blown timmed delayed and not one-time fuses. Thank-you verymuch!
Aug 30, 2008 | Weather King 10AJA2501AH Air Conditioner
Audio: hearing everything twice
you have a delay time on your home theater JVC, that is normal. So it's either you reduce the delay time of your JVC or do not use the TV sound. Set the delay time of your DSP so you can heqar the sound you wish... like the delay time of your surrond.
Mar 30, 2008 | Audio Players & Recorders
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
