Can not connect to the internet
The laptop is showing to be connected to the internet but is local only so cannot browse i went in got everything reset from the modem to the computer and is still having the same problem
  • 2 more comments
  • travisboswel Mar 12, 2009
    im connecting to wireless ive also tried to connect to the modem its showing im connected to the network but wont connect to the internet
    IVE ALREADY DONE THAT MY OTHER COMPUTER IS WORKING ON THE NETWORK
    ive went threw my firewall and as far as i know thats not the problem went threw my wireless conection and that did not do anything had at&t out and they cant figure this issue out either
  • Mark Van Skiver May 11, 2010
    Have you checked you browser settings?
    How are you connecting? Modem?Broadband?Wireless?
    MSG back I will try & help.
    Scholar:
  • 124 Answers
Sounds like you are computer savvy. Try this.
  1. Open network connections.
  2. if you have a local area connection running disable it.
  3. right click wireless connection. open view available wireless networks.
  4. mouse to change the order of preferred networks.
  5. Move up your network to top.
  6. left click your network.
  7. left click properties.
  8. Association set SSID & your network parameters.
  9. Cross fingers OK out try net.
  10. Comment me back see if worked or need to go further.
Good Luck! Please Rate.
Posted on Mar 12, 2009
  • 189 Answers
Check your firewall setting.
check if your connection is working or not, by connecting to other pc if possible.
check if dns etc config for your internet is ok, for this you must call you ISP and check if there are no issues with you connection.
showing connecting cant mean actually connected, it wont work unless confuguration setting are good.
  • s4singapore Mar 12, 2009
    it must be firewall then, which is blocking
I was on the computer, it froze up. now I do not have a wifi connection, I went into the control panel & under internet connection there was only Broadband, and Local area Connection Broadband. I finally...
Hi, Restore your computer to the last restore point before it froze using system restore. This should reset the computer where everything was working properly. Hard shut downs can corrupt files and drivers. Also do a full virus scan to make sure your system is clean.
Robert
Oct 18, 2013 | Acer Computers & Internet
I just got my acer one, when i went for wi-fi at local restaurant, the netbook showed connected but when i clicked on internet explorer it could not connect.
Try going to internet options, then connections, then go to lan settings. Make sure there's no check on use a proxy server.
Oct 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
LG TV will not connect to windows 7 laptop anymore.
no laptop stated or service tag
nor OS< opr.sys.
so the local screen is still OK
reload the video driver?
make sure power setting in CP are set to on all time no sleep.
make sure close lid, power settings is set to oFF. ?
Mar 23, 2017 | HP Pavilion dv9628nr Notebook
How do i setup my internet on the samsung nc10? i am wirelessly connected but when i go into networks it says te local connection is not connected because the network cable is unplugged but i dont have a...
Local area connection is meant for wired LAN connection. you can connect the internet using a straight clable wire.
on how to make a straight cable,below is the link
http://www.ertyu.org/steven_nikkel/ethernetcables.html
But as you have said you can connect using wireless,then in wireless adapter setting,
Assigned your IP address Plus Subnet Mask address.
Set your wireless access point IP address as your Default Gateway Address.
In Primary DNS address as provided by your Internet service provider.specify secondary address too,it available.
If DHCP server is available then you don't need to configure anything.
If you are trying to browse internet through a proxy server than Go to internet Explorer,Click "Tools", Select "Internet options ", Select Connection, Tick Proxy server and specify the IP address of your proxy server and the port.
you will be able to browse Internet now.
Rate this answer.
Dec 27, 2009 | Samsung NC10-14ROBL Notebook
I can't find my local area connection...how can i can i get it?
may in service pack 2 there is no LAN but you have to reinstall to he your original service pack that you to contact dell and one more thing for you have to install drivers of connection or internet because your service pack2 has not installed drivers
Dec 16, 2009 | Dell Computers & Internet
On my PDA MC70 it is showing WI-FI "unavailable"
This can get kind of complicated, and your wireless carrier may block this depending on the data plan. It's also different for the MC7095 (CDMA) and MC7094 (GSM/GPRS) models. You may also want to see if your device BSP release is up-to-date.
Here is some basic info for the MC7095 (Sprint):
Device was not connected to network to start.
Went to Start, Programs, Internet Sharing, tapped Connect, showed Status: Check USB connection. Internet Sharing drivers were installed on laptop computer, then device displayed Internet Sharing Status "Connected". We were able to browse the web on the laptop computer. Closed out of Internet Sharing (tap X on upper right hand corner). On device, tapped Start, Internet Explorer, attempted to browse to a webpage. Able to browse on both laptop computer and MC7095 device.
Note: Attempted to Disconnect the Internet Sharing session, unable to. The device does not appear to respond to the "Disconnect" option on bottom left of screen. When tapping "Disconnect" the option light up as if being tapped however the device itself shows no other changes and Status still displays :Connected.
***FYI*** In testing with a different MC7095 (BSP33) we experienced the same issues with not being able to "Disconnect" the Internet Sharing session.
Jan 29, 2009 | Symbol MC70
Help mi out plzzzz(wireless problem)
what you can see on your network connections? If you can see some icon of internet connection or local network connection you can right click and then point to properties after that you can see the local area connections properties. double click the Internet protocol (TCP/IP) click it and then click obtain automatically ip address. Some wireless network, you can see the network provider which you can see on your network locations. Sometimes you can put specific ip adress of your provider. If not? you can make your own network connection, right click the internet connection and then click properties follow the instruction and go to network connection and sign up your username and password so that you can access through internet connections.
Jun 25, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
