I have a Sony STR-K502P home receiver. While watching a program the other day the center channel stopped working. Prior to that I had recently noticed a clicking noise like a relay switching off and right back on. I am assuming this was one of the blue rectangular relays on the main board. I have taken it apart a couple of times since and resoldered some cold joints but nothing seems to have done the trick. I also placed a non conductive thin layer of foam underneath the main board just in case it was a grounding issue. Should I replace the center channel relay? How do I determine which one is for the center channel and a part number for it. I also read in a forum that my output transistors could be bad. There are 2 for each channel. Again, which ones are for the center channel and how can I get a rating or a part number?
    Genius:
  • Audio Player... Master
  • 1,054 Answers
It wouldn't be your output transistors. If they go bad they blow the fuse. Sounds like a speaker relay problem. Have you checked the solder connections on the relays? They sometimes break down. If that doesn't help, I would replace the relay. Center channel goes through RY501. Sony p/n: 1-755-170-11.
Posted on Apr 22, 2013
5 Suggested Answers
nwj2468
  • 76 Answers
SOURCE: Sony STR DE835 center channel issues.
it could be your wire. try using different speaker wire. if it still has that same problem, take the cover off and tap on the amplifier.
Posted on Mar 01, 2009
  • 5 Answers
SOURCE: Sony STR-DE845 center channel cut out, receiver clicks
I have fixed 3 shorts on my de845. 2 have been caused by cracked solder joints. they were speaker cutout problems...yours most likely is the center channel relay on the main board. take the thing apart. you need to get to the back of the main board and re-flo those solder joints. get your geeky pc buddy and do it together(buy him a sixer). its really not that hard...just a bunch of screws. disconnect everything from the main board including the front plate. be careful with the ribbon cable...mine is hurting at this point. not meant to be removed so many times. put it in straight. my leads bent, but was able to straighten them. there are 5 relays together, one for each channel. they are white cubes and prb a little smaller than the tip of your finger. its the 4 leads on each of these that you want to take a soldering iron to . i'm not sure which ones the center channel so do them all in that area. it may be hard for you to tell which leads they are so just go overboard and at least get everything in the vacinity. i did all component leads because who's to say another's not ready to go bad. you've gone this far. touch the heated up tip to all the leads at the very end of the barb. you can reflow the solder without actually touching it. the metal lead will get hot enough. hold it until the solder liquifies, then let it cool. do this on a flat surface. my other fix once was a re-seating at the speaker switch a,b,a+b on the front plate. there are 2 boards plugged together there. i bent the leads slightly so they seated in more tightly. if your left or right front goes out, sometimes thats an easy fix...try b if you're using a, or the opposite. don't forget the speaker cables. if you're using both zones then you prb already figured out you need to re-flo! test and cross your fingers. good luck.
Posted on Jul 27, 2007
  • 15 Answers
SOURCE: Speakers Cutting Out
I posted this solution on FixYa to help someone who had the same problem, or at least a similar problem. If you remove the slotted panel underneath the bottom of the receiver, you can gain access to the underside of the main circuit board. There are 3 relay units there, they are blue boxes that can be seen if you shine a torch down through the top. I found the solder joints on these relays looked as though they had broken away from the board, there appeared to be a dark ring around the pin of the relay. I re-soldered 4 of these connections, and, so far, that seems to have done the trick. Time will tell. These relay units connect and disconnect the speakers. There is one other relay that is mounted on a seperate board above the main board, that I can't access easily. If this one is also faulty, I will be un-able to fix it, as it would involve removing the entire guts of the receiver. If any of your technical team disagree with my remedy, or can offer any other solution, that would be appreciated. Thanks.
Posted on Sep 15, 2008
  • 5 Answers
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Posted on Mar 19, 2009
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Connecting a turntable to Sony STR K502P
Use RCA Cables from the TT to the Aux in on the Receiver. You may need to use a pre-amp inline from TT to Receiver.
http://www.bhphotovideo.com/ has a few.
Mar 17, 2014 | Sony STR-DE485 Receiver
I have a sony str de-475 amplifier and the centre speaker stops working after about a minute. leave amp powered down for a while and it works again but only for about a minute
Try replacing the center speaker with one of the left or right speaker and run it for sometime ( do not connect the center speaker to any other channel ). If the system does not cut off the center speaker connection this way indicates a short in your center speaker.
But with the L/R speaker if the system still stops working you have a hardware problem and will need professional help to fix. 5.1 amps are complicated and difficult to access even for an experienced technician.
Jun 22, 2011 | Sony STR-DE475 Receiver
When trying to watch a dvd through a blu ray player, the background sound is coming in loud and clear, however when the main actors talk, their voices are not coming through.
If you don't have a center channel you will experience this problem. The center channel is where all dialog is sent to. To fix it, you need the set the receiver to phantom center. Go into the setup menu into speaker setup and tell the receiver that you dont have a center channel installed. Once you do that, it will send dialog the the front left and right speakers.
Good Luck
Jan 07, 2011 | Sony STR-DE575 Receiver
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Rear speakers L and R not working
if its a 5.1 channel home theater,it means you have to hook up the subwoofer or maybe a center speaker to its terminal to have them all working. 2 front speaker,2 rear speaker and 1 center speaker or subwoofer =5 and amplifier is 1 so it is a 5.1 channel.hope this help..
May 31, 2010 | Sony STR-DB940 Receiver
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
Mar 17, 2009 | Sony Audio Players & Recorders
Center Channel not Working
Check that it's center speaker in the set-up menu is on and that the sound field that it's in uses the center speaker. try it in pro logic. It could be a bad solder connection on the speaker terminal or on the relay in the receiver.
Feb 24, 2009 | Sony STR-DE675 Receiver
Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Jan 07, 2007 | Sony STR-DE945 Receiver
167 people viewed this question
 Grubhead
Grubhead
