Question about Samsung CLP320 AllInOne Laser Printer
Cartridges has been replace but the error light is still blinking
Need to reset the printer. which usually means printing a test sheet and scanning it if your printer requires. press the power button and check if anything pops up on your computer, usually something comes up.
Posted on Apr 21, 2013
Ready light on. Error light blinking once/second.
In some KonicaMinolta loose counter wire make start button blinking, fix wiring.
Sep 14, 2015 | Konica Minolta PagePro 1350W Laser Printer
I put in new ink cartridges and now there is an E and 2 red blinking lights
Which lights are blinking red? What is the rate of the flashes? I'll assume that one of the blinking lights is the power light (just means error).
If the either of the ink cartridge lights is blinking rapidly, the cartridge may not be seated correctly. Try reseating the cartridges and then press OK to clear the error. If it is a less rapid flash it could be that the print head isn't reading the cartridge ink level correctly. Please note: refilled or non-Epson cartridges may not be read correctly due to information stored in a chip on the cartridge or in the printer.
In this case the problem may be in the print head and Epson doesn't recommend cleaning this yourself. You can replace it. (On other inkjets, pop out the cartridges, remove the print head and wipe with soft, lint-free cloths or q-tips dampened with bottled or distilled water (wring out excess water). On each section, you wipe away from the nozzles. Then wipe off the inside of the print head carriage (contacts) as well. Dry everything with a dry cloth and reassemble the printer.)
If the Check paper light is blinking check for a paper jam or the printer looking for a different paper size.
I hope this helps.
Oct 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer will not communicate with computer. tried unplugging it also unplugged computer and tried restarting. Green light blinking and alternating betwee 1,C,E. Amber light blinking at bottom left
The error indicates a communication failure between one of the cartridges and the printer. Try to check which cartridge is causing the error by inserting one cartridge at a time. Replace the cartridge(s) causing the error. If error continues, you can also contact Lexmark technical support to further investigate the problem. Thanks.
Sep 17, 2010 | Lexmark X2600 InkJet Printer
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Red ink light blinking, won't feed paper. Have
this is hp security error, for ink cardtridge,(the ink cartridge has internal/acess counter), you need to try change cartridge, if contuinue send to hp service center
Nov 27, 2009 | HP DeskJet 940c InkJet Printer
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Both paper and cartrige lights blink & E in coppies won't leave
just replace the cartridges its the cartridge replacement error .or check out in the printer for any paper jam that also gives this E error on the printer.but mostly its the cartridges error.also try cleaning the cartridge before replacing them sometimes the cleaning helps.
Dec 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
Samsung CLP320 AllInOne Laser Printer Logo
51 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
