Question about Dishwashers
Frigidaire FDB520RHB Dishwashers : We bought this dishwasher about 3 months ago. Today I ran the washer before I left to do errands and when I returned, I believe the washer had finished its cycle. But about an hour later, I noticed it had started up on its own? It then proceeded to run for almost 3 hours before my husband canceled the cycle. We were kind of waiting to see if it would stop on its own, which is why we let it go so long. I think it usually takes about 1 1/2-2 hours to wash. Could someone please tell me why it would run for so long? What would go wrong to let it go so long and is there anyway to fix it? It's so irritating since we really just got it. Thank you so much.
  • Dishwashers Master
  • 3,247 Answers
Try to run the dishwasher on a short cycle like rinse and see if it finishes the cycle.
It is likely the heater or hot water temperature is not reaching the desired level and this could cause the extended wash cycle. Feel water temperature inside dishwasher after some time. If cold then it is the heater not working. Perhaps try without Heat Dry Cycle. That will also extend the cycle if heater is not working well.
see cycle diagrams in the page 2 of this sheet. Gives you and idea how Heater Delay affects cycle times.
Posted on Apr 21, 2013
SOURCE: Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Posted on Nov 01, 2007
futureloginn
  • 734 Answers
SOURCE: Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Dec 12, 2008
SOURCE: Dishwasher keeps running & won't clean dishes
If bottom arms is falling of then the assemly is wrong. Pull eveyrthing out and put the arem in before the other parts. reassemble and twist the horseshoe piece till it locks. that should keep the arm in place
Posted on Mar 09, 2009
SOURCE: dishwashwer won't start and can't reset to restart
Check the float. (dome shaped thing inside the washer) Mine was stuck but as soon as I lifted up on it and then reseated it I was able to return to normal. Almost too easy. Saved $!
Posted on Apr 23, 2009
tattootech2
  • 72 Answers
SOURCE: Frigidaire dishwasher won't end cycle - will run
I would say the resettable thermostat has failed. There is a thermostat which senses the water temperature, and when it fails, it causes the dishwasher to run constant. Replace the thermostat underneath the dishwasher and that should cure problem. Part number is 154290204 (I know the number off by heart, that's how often it happens!)
Posted on Apr 07, 2010
Frigidaire dishwasher model FDB520RHS2 will not advance pst wash- just keeps washing draining and refilling the wash. does not advance. Left it run for 3 hours, still wash only
We had a problem with our dishwasher, it just went crazy one day and lights would light up but ours did not wash or anything...anyways upon further investigation found out by taking 6 large round head screws off,, the handle and outer cover came off, then there was a cover that was covering a circuit board and this was the brains of the washing machine, ordered the part from sears 160.00 and washer is all set. good luck. oh ya, upon further exam. when I took the board off could see discoloration on part of the circuit board. this means burned out resistor or fuse.
Mar 22, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
My Frigidaire dishwasher will not start. It was working fine about a month ago. The lights on the panel are working and I had the water line checked and it is o.k. I cannot find a serial number but the...
My Frigidaire 500, 1100, 1400, 1500 & 2400 Series Dishwasher was purchased a month ago and it will not start either. The 8 second lock under "Heat Dry" is lit, but nothing happens when you press any of the other buttons. Any ideas?
Mar 27, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
My Frigidaire dishwasher is leaving soap, a lot of soap, on dishes under where the dispenser dispenses. It just started hapening. Also, it has always left a light film on the clear glasses.
I scrubbed the screens with a brush and added two cups of white vinegar to the bottom of the washer, then ran it. Cleaned up nicely. I most likely will add a cup of vinegar once a week.
Sep 13, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire professional series dishwasher has a lock symbol
did you try holding that button for 3 secs, it should unlock it
Mar 04, 2009 | Electrolux Frigidaire Professional Series...
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
My dishwasher is leaking at the bottom corners of the door
Mine is doing the same thing and I just bought it three days ago.  I call the store's tech department and they tell me the unit I bought has a service bulletin on regarding leaking at the bottom of the door.  They apparently have a repair kit for the problem.
Oct 11, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
174 people viewed this question
Top Dishwashers Experts
