Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Is it possible to replace a point type ignition on a Briggs &Stratton engine, model # 326434 with a electronic ignition?
16 HP motor with ca cast iron block with a horizonal crank shaft
co7196
  • 3433 Answers
SOURCE: 8 hp briggs no spark,new coil ,new electronic
make sure the plug wireisn't grounding on sheet metal. Verify current to ignition module and that module is securely mounted for grounding. Negative side of coil to module, pos to ignition switch or starter button . Chk for current at coil +. . Coil -- should pulsate when cranking. Ensure there are no inline fuses, fuse box fuses, or fusible links incorporated into wires lesding to module. Good Luck_Ned_
Posted on Oct 31, 2009
SOURCE: need point gap setting for 8 hp Briggs and
My early 60's B&S 8HP model 143302 says on the engine tag .020 point gap
Posted on Jan 26, 2010
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Posted on Apr 23, 2010
  • 760 Answers
SOURCE: trying to change the points on an old briggs and
Need to know what model Older engines have points "under" the flywheel. Use a wheel puller to remove after removing the nut in the center of the flywheel. Newer motors have an electronic ignition module. Follow the small wire from the magnetio. If it goes under the flywheel then you have points. If it goes to a small device on side of motor, you have electronic. You can go to http://www.briggsandstratton.com/ and look up your odel number.
Posted on Jul 01, 2010
roadtech7
  • 297 Answers
SOURCE: I have a 14 hourse Briggs$ stratton cast iron
Do you have a starting or running problem? Any spark will ignite gasoline.
Describe you exact problem, and I can help.
Thanks,Matt
Posted on Dec 11, 2010
13 HP briggs and stratton intek motor on a pull behind weekend warrior brush cutter
Manuals - Briggs & Stratton
https://www.briggsandstratton.com/us/en/.../manuals
Briggs & StrattonFind Briggs & Stratton manuals online by selecting your lawn mower or product type &engine model number. Never worry about losing an owners manual ...
Sep 10, 2015 | Measuring Tools & Sensors
I have bought a 5 hp.briggs &stratton and the
my advise is to leave it....most are pre set.Most are a screw....turn clockwise for higher revving....is the motor under stress?...if so a small adjustment maybe in order.
Jul 22, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Trying to change the points on an old briggs and stratton 8 hp engine
Jun 23, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
65 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
