My asio driver control panel says the realtek hd audio aux input is unavailable and i cant record anything. its like the computer does not recognize the input
    Sergeant:
  • 254 Answers
Remove all the connections and reconnect every thing again as it was orignally connecte .and then try if the same problem still then reinstall the drivers if still the same problem then just check out it must be inter board error in the pc as its not detecting the device.get the bpoard repaired to make it work.
Posted on Mar 12, 2009
  • 523 Answers
You have to install the driver.
  • 19,396 Answers
Try reinstalling the driver software , this will also reset all settings.
Alteratively, try first doing a system restore to a date before you started having this problem.
Neither the Cubase ASIO driver nor the Zoom H4n Pro ASIO Driver can remain connected to the HP Spectre x360 Realtek Audio onboard chip. Recording, playback loop is awkward.
ok , x360 got that.
what are you doing, attempting
then tell the story.
what OS?
W7,W8 or W10
is it virus infected.
what are you doing.
making a movie
what? what job are you you doing, and the results are./????
May 15, 2017 | HP Computers & Internet
Lexicom Lambda is not working! New user
right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
My cubase LE4 software says the ASIO driver Omega ASIO cant be started? i follow the directions and try to record but the track remains blank
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 15, 2011 | Lexicon Omega Desktop Recording Studio...
Computer dont recognizing audio device (no sound device?) after installation of windows 7. a tried to deinstall and reinstal realtek hd audio drivers, and its still the same??
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 10, 2010 | ASUS M2N68-AM SE2 Motherboard
Just purchased behringer u-control uca222. When first plugged in the power led came on. Downloaded the midi driver at the behringer site and attempted to install. Power led went out then the midi drivers...
The UCA222 is a USB AUDIO Interface, not MIDI.
You want to download the ASIO driver(s) and install those again. You then have to go to whatever audio software app you are using, and 'set up' the ASIO drivers within your audio software itself (read the manual or look at some of the headings under Preferences or Settings in the software window itself).
Also go to the Audio Settings panel and configure your Audio Ins / Outs, make sure they are selected and 'enabled'. You should see Behringer USB listed when you click on the audio out tab. Just click on it with the mouse button and release.
You also may have to go to the ASIO Control Panel (again from within whatever audio app you are using) and tweak whatever settings are there. Make sure the ASIO driver is selected (not the MS Win or Realtek or whatever), and check that the audio outputs are likewise enabled there.
(Some apps won't output any sound while you are adjusting the Control Panel settings etc, so you may have to adjust the settings, then close the panel, before you'll be able to test for audio output, then if it doesn't work, go back into the panel and adjust some more and try again.)
If you are trying to control a VST plugin or VST Instrument via MIDI, you just need to go into your audio app's Midi Settings panel and likewise make sure your Midi controller kbd (or other Midi source) is selected and enabled, and that the appropriate Midi channel is enabled (or you can just select Omni Mode and it will listen to all Midi channels).
Of course you must have some sort of MIDI interface to connect your keyboard to your computer. Many new kbds have USB in which case it will send/receive midi via USB (tho you may have to install the proper drivers for your specific keyboard first. - they will be on your install CD that came with the keyboard or available on the internet).
Good luck! Hope some of this helps.
Mar 19, 2010 | Behringer U-CONTROL UCA202 USB-Audio...
I have a Realtek HD audio driver on my Windows XP Media Center Edition version 2002 with SP3. I can listen to anything online and offline but I can't record anything using my Wave Pad sound editor or...
Open your control panel.
Click on Sounds and Audio Devices with the control panel in classic mode.
Click on the Audio tab.
Is Realtek HD Audio Input Device listed as the default device under Sound recording?
If not, select that from the drop down list and click Apply/OK.
Mar 18, 2010 | Gateway Computers & Internet
To play my vietcong game i have to disable sound otherwise it crashs
I had the same problem and solved it by selecting "Disable front panel jack detection" in the Realtek HD Audio Manager "Connector Settings" dialogue box.
Running Windows 7 Ultimate 64-bit on an ASUS P6X58D motherboard w/ integrated Realtek audio chip.
Aug 02, 2009 | Jack Of All Games Vietcong for Windows
Realtek HD Audio Troubleshhooting?
I had the same problem with both my Biostar 550 and Gigabyte P35 motherboards, both of which use Realtek ALC888 HD audio. Its got lots of fancy eq and effects but a crippled record mixer with greyed out sliders. I emailed realtek and they responded that its a Mixer Record type audio mixer only and follows microsofts HD audio specification...so blame microsoft or Realtek...or both. There is NO workaround for this.
The solution is to use a sound card with AC97 audio or if youre lucky enough to find a newer one with HD audio and a less crippled mixer. Problem being the industry seems to have embraced Realtek who seems fixated on offering partially disabled mixers. I purchased a Diamond Xtreme 7.1 sound card from officmax for 30 bux. They also have a 5.1 version for 20 bux. The main rec output is set to a fixed level but the individual rec. sliders ARE enabled. Recorded audio ends up being about 10db low but you can always boost it n post production using a recording program like audacity (which the sound card comes with - there are newer versions of audacity available so dont use the included version). - The only way to get FULL functionality
- ALL sliders is to find an older AC97 audio card. There are good ones and bad ones so it may take a few. Try the Diamond Xtreme card first and if you dont like it you can always take it back. This link is for the $30 verson. http://www.officemax.com/omax/catalog/sku.jsp?skuId=21080508&searchString=diamond%20xtreme&category_Id=null
Dont hesitate to send Realtek a "concerned" (not nasty) email about this. Hopefully If they get enough...they MAY take it seriously...but I wouldnt cross my fingers.
Good luck,
Dave
May 21, 2008 | Microsoft Windows XP Professional With...
My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
46 people viewed this question
 Grubhead
Grubhead
