Question about Tomtom GPS
I cannot hear the vocal instructions
I cannot hear the directions...is there a mute button I pressed by mistake?
    President:
  • Tomtom Master
  • 489 Answers
There's a VOLUME slider to increase the speaker/output volume. You can reach this option from the CHANGE PREFERENCE menu option ... or...
Tap the left or middle pane of the (Horizontal) status bar on your driving screen, and the volume slider will appear. Then slide the volume to the right, for higher volume.
If your TomTom GO device internal speaker is not work, you can consider piping the sounds (via FM) to your car speakers ..
Posted on Jan 02, 2014
  • LP Jan 02, 2014
    There is also (in the MENU - Change Preferences ... a button for you to TURN OFF SOUND or TURN ON SOUND.
Why can't anyone hear me when I call or when I answer a call?
yep there is a problem with your microphone if you are sure the phone has no other problems. Sometimes when you are talking and if the screen is a touch screen your cheeks can by mistake press the mute button. but in that case you can use the SPEAKER OPTION and see if it s working or not. Hope this helps.
Jul 24, 2013 | Casio G'zOne Rock Cell Phone
I can hear the caller but the caller can't hear me
Look to see if the Mute button (or Hold button) has been pressed. If so, press the Mute (or Hold) button again to turn it off. With Mute ON, you can hear what your caller is saying, but they can't hear you.
Jan 24, 2011 | Uniden DECT 6.0 Cordless Telephone...
Person can not hear me. is my headset muted?
I am putting the link for the user guide for the 500A amplifier below. Look at page 9 for Mute Button instructions. This should help you to determine whether your headset is muted or not.
Plantronics User's Guide
Good luck from Headsets Direct!
Oct 14, 2010 | Plantronics Voyager 500A Deskphone Adapter...
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
Can't hear vocals on microphone
go to your control panel ... select sound (speaker icon) and make sure the microphone is not muted.
May 27, 2009 | Magix Music Studio 2005 Deluxe for PC
No voice or sound
Did you check that you didn't activate mute?
If it is on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 10, 2008 | Motorola Mobility H500 Wireless Headset
Blue tooth not transmitting to caller
Did you check that you didn't by mistake activate mute? Also, check that there is nothing obstructing the microphone hole on the headset.
If it is indeed on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 08, 2008 | Motorola Mobility H500 Wireless Headset
HELP
You can't program numbers vocally to you headset, you can only program vocally to your phone only if your phone has the voice dialing option. I have a H500 and can inform you of what I know. To turn on, hold button until blue light flashes once or twice, to turn off is the same thing. To pair your headset with your phone you have to hold down the call button until the light stays on then you use your phone to pair. After pairing the headset will flash quickly then discontinue. If you are using your headset and receive another call, you press the call button on the phone to answer the other line and to also release the call. The volume up and down buttons are found on the top and bottom of the headset, up and down is dependant on which ear you wear your headset. To mute, hold both the volume up and down buttons at the same time, this also unmutes the call. Hope this helps!
Sep 08, 2007 | Motorola Mobility H500 Wireless Headset
No vocals!
Maybe your headphones are pulled out halfway.
Feb 11, 2007 | SanDisk Sansa m240 MP3 Player
GPS Logo
87 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
