Magnavox turntable arm will not move to record
Just got this console unit, plays great, but does nothing if you turn the auto knob, and arm will not go over to the records. I also think the spindle needs replacing as it will not drop records. Sorry, not a expert on the correct terminology.
  • cbpbgv
    cbpbgv Apr 23, 2013
    I'm sorry I should have said this is a vintage Collaro ( Magnavox) from 1976.
  • cbpbgv
    cbpbgv Apr 23, 2013
    Am in NJ and having a hard time finding someone who might be able to work on this unit, it's pretty old. Any suggestions on getting it to work appreciated. Does Play Great!
djproaudio
  • 515 Answers
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
  • 92 Answers
SOURCE: Turntable does not rotate when switched 'on'.
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Posted on Jan 04, 2009
  • 104 Answers
SOURCE: JVC L-E5 Turntable arm will not move to the record.
This turntable is linear tracking, meaning that the tonearm slides from side to side. Inside there is a belt coming off a motor and over to a pulley that will move the tonearm from left to right n right to left. If you feel qualified it can be replaced with moderate from the bottom after removing the bottom cover with the power OFF. the belt can be found here.
http://www.turntableneedles.com/46-Inch-Square-Belt-Small_p_352.html
Posted on Feb 11, 2009
Vinylking
  • 3 Answers
SOURCE: JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Posted on May 17, 2009
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Why won't our arm on our record player advance to play record on auto control? Lifts, moves back and returns to original position.
Try adjusting the counterweight on the back. Average weight setting is 1 gram. most high end RPs have it and it's a 'turn clockwise to increase' deal.
If it's a cheapo, there may be something interfering with the arm. possible a spiderweb inside! or??
Aug 17, 2014 | Audio Players & Recorders
My turntable turns and the arm moves onto the record but then the arm moves back and the turntable shuts off. What's wrong?
The auto reject/auto return lever has been advanced therebt tripping the arm to return to the pick up rest.It needs adjustment.
Jul 13, 2014 | Denon Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
How do you shift to play records. When I turn to phono on dial it turns the unit off. I have a radio cd player with CR24 turntable
Move the tone arm off the rest on to the record and it will start to spin. There is a switch that turns the player off when the tone arm is on the rest.
Feb 25, 2011 | Crosley CR248 Turntable
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
My console can only play 45 rpm records
There should be a record size selector switch somewhere. It will move the arm to the positions for 12inch 7inch and 10inch records. It must be set to 7inch or 10 at the moment. For 33 it should be on '12' and for 45 on '7'.
Jul 11, 2009 | Audio Players & Recorders
159 people viewed this question
 Grubhead
Grubhead
