Question about Canon PIXMA MX922 Wireless InkJet MFC / All-In-One Color Printer
Head alignment is failing - Canon PIXMA MX922 Wireless InkJet MFC / All-In-One Color Printer
2 Suggested Answers
sys_admin
  • 829 Answers
SOURCE: head align fail
Try cleaning the printhead with a cotton swab soaked in isopropyl alcohol.
Posted on Jan 14, 2009
Why has head alignment failed after many tries?
It is possible you have a bad print head or you may be using the wrong media for the head alignment. It is also possible that the optical sensors that control head and paper movement are dirty. Knowing the type of printer you are dealing with would allow me to give you a better answer.
Sep 19, 2015 | Office Equipment & Supplies
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
Auto head align Fails screen says "change H
You need to print an alignment page. After you print it, you will be able to align the page using the up and down arrows.
Jan 27, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Auto Head alignment has failed twice. Do I try until it works?
This depends on why it is failing. You can try to perform a manual alignment through the software if it will let you,(printers, properties, preferences, services, alignment) or just don't align the carts if not necessary (you don't see print defects). On this older model, it is possible that it is related to a scanner issue as well.
Sep 29, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Head align fail
Jan 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MX922 Wireless InkJet MFC / All-In-One Color Printer Logo
601 people viewed this question
old marine
old marine
