Question about Bowflex Treadclimber
I replaced the control board in by Bowflex Treadclimber TC3000 and am not sure if I reconnected the wires properly. Do you have a diagram for this?
Replaced both the control board and the motor, now the belts run but Calibration continues to "fail"
  • 6 Answers
SOURCE: calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
SOURCE: FOR BOWFLEX 1000 TREADCLIMBER. GRINDING NOISE
Click here to download Bowflex TC1000 Treadclimber assembly/troubleshooting procedures.
Adobe 5.0 or above needed to read it -->http://get.adobe.com/reader/
Posted on Mar 23, 2011
ercupa190
  • 12223 Answers
SOURCE: my bowflex treadclimber just stopped working. The control board workers bu the belt will not move.
1) Lube the deck belt, this is problem by lack of maintenance.
2) Test the input voltage motor, if there are voltage, the motor need repair.
3)Test the outputv voltage board, for input voltage motor, if there are NOT the board is faulty.
See the diagram attached. God bless you
Posted on May 16, 2012
ercupa190
  • 12223 Answers
SOURCE: Control panel on bowflex treadclimber isn't working.
adjust the reed switch, see the diagram clean it, tight the plug very well.
God bless you
Posted on Sep 23, 2012
How do I fix L5 error on a Bowflex TreadClimber tc3000
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 22, 2016 | Bowflex Exercise & Fitness
I purchased a replacement power cord for my Bowflex TC3000. I plugged in the new cord and it is not working. Is there a known incompatibility with after market power cords for this machine?
If you have access to an ohm meter then you can verify if the plug is good or bad and you can use a volt meter to verify that the outlet is working or not. The first video shows a generic way to ohm out an extension cord. this will also work with yours. The second shows you how to check voltage at an outlet.
Jul 06, 2016 | Bowflex TC3000 Treadclimber
Why would my bowflex tc3000 not calibrate?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 14, 2016 | Bowflex Nice Tc3000 Treadclimber Bow Flex...
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Treadclimber led board codes
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 08, 2012 | Bowflex TC3000 Treadclimber
My Bowflex Treadclimber keeps coming up with an Error L5. This error message shows up 5 seconds after turning the machine on. My husband looked it up yesterday and said that the machine needs to be...
L5 due to the screen is actually LS (lost signal) the first place to check is the gap of the speed sensor. under left treadle 2 black wires. Removing the rear covers will allow you to see the lwr cntrl board and move the belt by hand. The gren led light should flash once per revolution of the drive pulley. If not then it is the speed sensor. Adjust sensor to pully about thickness of a credit card. then calibrate unit.
LS is also tripped by any broken wires or bad connections. Start at sensor and board first.
Jul 21, 2009 | Bowflex TC3000 Treadclimber
Bowflex tc 1000 treadclimber
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Sensor wires detatched during initial assembly of Bowflex TC1000
You will need to make contact with bowflex if you broke the item. You may be able to glue back the item as well. The front lid come off, sometime you have to tilt the machine with another person. This will allow you to get to the under side.
Jan 28, 2009 | Bowflex TC3000 Treadclimber
Calibration Failed
make sure speed sensor isnt to far away from left wheel or did not get unplugged from circut board
Dec 25, 2008 | Bowflex TC3000 Treadclimber
Bowflex Treadclimber Logo
218 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
