Need manual and/or reason/use of small plastic tank above pump??
SOURCE: need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
SOURCE: coleman powermate 3000 pressure washer had
Check the coupling between the engine and pump for slipping or breakage. A pressure regulator may have broken it's spring allowing water to bypass the pump.
SOURCE: My neighbor was getting rid of an old coleman
The Manual for the Coleman Pressure Washer PW0881800 can be found here:
http://www.powermate.com/pdfs/2007/11/30/manual_pw0881800.pdf
Refer to page 5 of the Manual for the start-up procedure.
