Will not spin out water in the final cycle
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
SOURCE: my gas dryer spins but doesent get warm at all
When you turn it on listen for a clicking sound. If you don't here that. The electric igniter needs replaced. And sometimes theres a circitboard that goes bad. But its gas, and there fore very dangeruse. FOR YOUR SAFETY IF YOUR NOT EXPERANCED WITH GAS APP. GET A PRO TO WORK ON IT.
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: dryer spins but will not heat
Ok this can be 1 of 4 problems:
1. your breaker is connected to the only one side of the panel
2. your breaker s fried and needs replaced.
(both of these can be elliminated by using an electrical tester on the outlet)(240 Volt)
3. you temperature thermostat if bad
4. your heating element is bad.
Or if the dryer heats a little then stops heating your vent hose may be kinked or plugged.
SOURCE: I have a Roper electric dryer 5 cycle heavy duty
It has a bad thermal fuse located on the blower housing . A narrow white piece with 2 wires attached to it . Unplug dryer before replacing .
