Question about InFocus Lamp for the IN3114
Infocus in3114 projecter won't power up
Infocus in 3114 won't power on (nothing) Can the power supply be replaced?
4 Suggested Answers
SOURCE: infocus x2 dose nothing
Assuming the power outlet and cable is OK the most likely problem is the power supply and needs to be replaced.
Posted on Dec 30, 2007
tech4allmen
  • 666 Answers
SOURCE: My Infocus 5700 won't power
We can fix this. I believe you are handy enough to fix the power supply of this masterpiece.
I had 100% the same problem and finally figured it out. The problem is with one of the capacitors, and after lots of trial and error, and asking for advice, here it is: The capacitor is "C16" - a small blue electrolytic - 100uf 16v. It is in the center of the power supply board partially hidden by a black heat sink and the large silver chunk of metal.
Swapped for a 25v 100uf I had lying around and she works like a charm now.
Here's how it looked like on mine:
images?q=tbn:and9gcte64-3vvp7h6vtswd6pxijyyxdvcyifqgbtov0jpszkmueqklupg
Posted on Aug 24, 2011
SOURCE: infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Posted on Dec 12, 2012
In3114 dead pixels
You should change the DMD or the optical engine. DMD abouut $350
Engine about $650 P5X84-2200 OPTICAL ENGINE, IN3116
Nov 28, 2013 | InFocus Corp. Open Box InFocus IN3114 DLP...
I have RED verticle lines all the way across the screen fro top to bottom 10 minutes after I turn my Panasonic PT-52LCX65 TV on. Is there a solution?
Hello
Check and replace the main filter capacitor in the power supply section. Replace all of them in the secondary section of the power supply too. The problem is due to insufficant smoothing and regulatio fo the power supply section. If main smoothing capacitor gets value deveoped, it won't supply enough voltage to the switching section, and switching section also will go inefficient. Replace all of them. It won't cost not much. OK.
Jun 22, 2011 | Panasonic PT-52LCX65 44" HDTV
The red light keeps blinking and tv won't turn the fan won't come on either
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help out in solving the problem....
Jun 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
InFocus LP120 that will not power on.
it project?..but in 10 sec.it off? im pretty sure that the lamp ballast of your projector is defective. but if deadset? check the power supply and your power cord. if still not working your power supply board is defective.
Oct 28, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
My infocus lp650 won't power up no lights nothing
One way of telling if its the power supply is apply power to the projector and look at fans on the side. If they don't move then its a power supply issue. I can fix this for you for less then it cost to send to infocus or to a repair shop. Ebay Id is Gtitubro
May 11, 2009 | InFocus Work Big LP650 (Refurbished)...
Infocus x2 dose nothing
Dec 06, 2007 | InFocus X1 Multimedia Projector
InFocus Lamp for the IN3114 Logo
215 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
