Question about Garden
Re-thread throttle cable to hand control on handle
I have a Rover hand mower (Briggs & Stratton motor) and I need to re assemble/thread throttle cable in it's little case then I will be able to re-attach to mower handle bar. Cannot figure out how the shaped wire sits to engage the cable to start/ run/ stop.
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
SOURCE: briggs & stratton 4hp push mower
why dose my motor cycle up & down in rpms
Posted on Aug 05, 2009
freetek
  • 5568 Answers
SOURCE: briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Posted on Aug 20, 2009
hunter19_46m
  • 7482 Answers
SOURCE: 4.5 hp Briggs& Stratton push mower will not run
You need to rebuild your carb. The diaphram in the carb has gotten hard and is no longer acting as a fuel pump to pump the fuel to the carb. Get a rebuild kit and a compressor (for compressed air) to blow out the jet passages. It is an medium to easy job, just watch the small parts. ----------------------------------------------------------------------------- Hint: Before you remove your fuel/air jets, bottom them out first and count the number of turns it takes to bottom them out and mark it down for each fuel/air jet. When you go to reinstall the fuel/air jets bottom them out and then back them back out to the number of turns before removal. That way the fuel/air jets are set to the right number of turns when it was running right. Good Luck, I hope this helped Please rate me...Thanks
Posted on Jan 04, 2010
How do I remove the carburetor of a Briggs & Stratton model 287707?
remove the air cleaner assembly,then unscrew the 2 threaded bolts, should be 8mm head visable once air cleaner removed. disconnect fuel pipe,choke and throttle linkeges and backlash spring
Sep 26, 2014 | Briggs & Stratton Garden
Craftsman lawnmower
take back get new one handel probably broken
Aug 16, 2014 | Briggs & Stratton Briggs Stratton...
How do i repair the throttle control on my briggs and stratton engine?
Depends what you mean repair..if it is in place but it isn't pushing or pulling the carb linkage..check the small clamp at the point where it connects to the carb linkage,,that clamp slips and doesn't allow movement..set it to the correct movement and tighten..if you are talking replacing it..onhook at that clamp and disconected the cable,,just mark or remember what connection hole it came out of...then remove the handle bracket on dashboard..normally two screws...note depending on the model you may need to remove or loosen and set aside the gas tank..the cable comes in a complte kit or just the cable..I suggest the complete kit..but you can disconect from the handle and replace just the cable. After the handle and cable is replaced..push it to the open throttle and then push the linkage to the full throttle position and tighten the clamp...you can make further fine tuning from there..
Jun 24, 2014 | Briggs & Stratton Garden
I have a Briggs & Stratton 10 HP engine, model 220707 that I could use some help with the governor spring on?.
Should see a bracket with holes in it .and a small throttle bracket that has a hook shape the spring locks on to it.
May 20, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How do I adjust a throttle on a briggs and stratton engine?
If it the simple handle type throttle cable..push it to full tbottle and follow the cable to the carb..you should fund a small clamp that hold the cable in position..jus loosen and adjust the carb throttle to full throttle and tighten..then push it back to idle to make sure it Idles if not adjust the clamp again until you reach both throttle and idle..good luck..
May 17, 2014 | Briggs & Stratton Briggs Stratton...
Throttle cable assembly
The cable you are trying to replace is the OPC cable (engine brake cable), not a throttle cable like you are trying to fit. You need to take it back and get an OPC cable, which will have the correct end on it to fit into the bracket on the side of the engine.
May 19, 2013 | Garden
My 21" Mastercraft self-propelled, 3-in-1 mulching
There is a flywheel brake that is contolled by the safety bar of the handle. If the cable to the safety bar has broken or is no longer attached the the flywheel brake will be on. Not only that there is an ignition Kill switch as part of the flywheel brake. If the brake is on, the kill switch is activated.
Your mower needs some simple maintenence
1. Recoil assembly repaired or replaced.
2, Throttle cable and control repaired or replaced (Item 10 below link)
3. User Safety Bar cable adjustment or replacement. (Item 11 below link)
The above items are not a good reason to call your mower a parts source.
Without a model number I had to GUESS which model this was.
This is my best guess:
http://www.jackssmallengines.com/help.cfm#/MTD/125-478C054_(1995)/General_Assembly/0054900-E/00549000001
Thanks for choosing FixYa,
Kelly
Jun 07, 2011 | Briggs & Stratton Garden
Hello, I am using the Craftsman 675 Brigs & Station 190 cc lawnmower, and I'm trying to turn up the throttle. It apparently does not have a throttle adjuster, and I was wondering if there is any way...
After researching the engine application, I see that this 675 is NOT an OHV engine. It appears it is the L (flathead) engine with the standard features. The 775-875 Platinum series mowers have OHV engine applications. That being said, many mowers have the carburetors with the governed throttles set to run at the the OEM mandated maximum speed. Some (like the Briggs Quantum series engines) have the throttle plate still attatched. You would need to bend it back up and install an aftermarket throttle cable assembley (like Murray makes). You would connect the carburetor end of the throttle cable to the hole in the plate assembly that has the governor spring attatched. Some even remove the governor entirely (internal governor has to stay in) and connect a throttle cable on the plate controlling the butterfly in the carb. Your unit may have this feature with the plate having a few different holes in it in which you could install the end of an add on throttle cable.
Apr 09, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
As soon as my 10 hp Briggs & stratton engine starts, it goes to full throttle. I have no control
The engine speed is controlled by a governor and throttle position. There is a spring that holds the throttle (butterfly valve) against the slower position. When the motor is under load' the governor exerts force to open the throttle position. Make sure that all of the components are clean and not binding. Look for a broken or disconnected spring. It is also possible that the governor is stuck in the demand full throttle position.
Sep 11, 2009 | Briggs & Stratton Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
