Question about LG 42LG50 42 in. LCD HDTV
After tv is on for about 15 min the remote and tv buttons won't work it won't shut off unless you unplug it
  • Rrschnepp Schnepp
    Rrschnepp Schnepp Mar 12, 2009
    tv buttons don't work eather and what is the ir board
    Sergeant:
  • 320 Answers
Its the problem of the tv internal board as some components on the tv main cirfcuit board gets over heated and the tv reaches to HANG MODE and nothing happens.so just replace the IC 456UI on the main board of the tv which is inside the tv.which controls the tv internally to function it.if that ic turns faulty this can happen.if you are not familiar with reparing then get it replaced from a proper repair center.
thanks.
Posted on Mar 12, 2009
    Brigadier General:
  • 8,619 Answers
IR sensor is the infrared sensor that detects the signals from the remote. When it is bad you need to either replace the sensor ot the whole IR circuit board. Try using a diffrent remote to check if your remote is not faulty.
Thanks
Rylee
    Sergeant:
  • 254 Answers
Its going in stand by mode and pausing.just keep it unplugged from main power cord outlet for 1 hour and this will reset the settings and then try.also replace the remote batteroies and try out. afdter you start again just scan all the channels to reset every channel.
  • LG Master
  • 19,396 Answers
That is a faulty ir sensor on tv panel, try removing battery from remote, if problem stops, then it is the remote. if not , then the tv must be repaired and the ir board on tv replaced.
TV - Mitsubishi WD-62530 Will not power up unless first unplug from wall for approx. 15 minutes prior to turning it on or it will not power up at all).
Start with changing the capacitors that look bad on the PS board...I think you will find some that are bulged when you take the cover off, should be a easy and cheap fix
Oct 22, 2017 | Mitsubishi Televison & Video
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
Won't completely shut off
Do you have a separate Cable Box? It sounds like you are shutting off the signal to the TV and may have to push a 'TV' button the remote then the 'off' button to actually shut down the TV.
Nov 21, 2013 | PixiModo Reflection 15M 15-Inch Digital...
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Hi I have Prima lv 3228p tv and there is no volume it was working fine yesterday andtoday no volume
prima lv-3228p lcd tv-after 15 mins of play the screen goes funny and there is still volume but the remote will not function. you cannot even shut the unit off, only by disconnecting the power supply. If you wait 15 -20 mins and plug the unit back in it will work for approx 15 mins again- then it will start acting up again?/
Jan 13, 2011 | Televison & Video
Can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
May 17, 2009 | Sanyo DS31520 31" TV
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
LG 42LG50 42 in. LCD HDTV Logo
102 people viewed this question
Computer Repairing
Computer Repairing
