Question about Roper Dryers
Roper dryer serial # sm828087 will not spin out water after final cycle
Will not spin out water after the final cycle
SOURCE: final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Posted on Jan 08, 2008
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
  • 185 Answers
SOURCE: roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Posted on Mar 26, 2008
Lumpy816
  • 246 Answers
SOURCE: Roper Washing machine model #
Great question, here is your answer. You have to open the console (usually 2 screws in the front or back where the console meets the top of the washer) Pull the bottom of the console towards you and swing it up. Remove the 2 brass colored clips underneath by pushing down with a large screwdriver at the point where it goes into the top of the machine and press down while simultaniously pushing towards the rear. Now there will be a connector with a white, green and gray wires in it. Unplug this connector. Now tilt the top of the washer towards you (the top, front and sides all come off as one assembly) The washer will fill with water, but you will not be able to drain it unless you install a wire between the white and gray wires on the machine side. ( I would do this with the unit un-plugged and make sure you have a good connection by spinning it before you add any water. Likely the leak will be coming from the pump (white peice of plastic in the lower front with 2 black hoses going to it). If so, pry the two clips off the pump with a screw driver. Put the pump over a bowl to catch any remaining water. Squeeze the clamps on the hoses with a pair of pliers to remove them. A replacement part is availible at a local appliance part store or on line from the manufacture's web site.
Posted on Jul 11, 2008
  • 78 Answers
SOURCE: my gas dryer spins but doesent get warm at all
When you turn it on listen for a clicking sound. If you don't here that. The electric igniter needs replaced. And sometimes theres a circitboard that goes bad. But its gas, and there fore very dangeruse. FOR YOUR SAFETY IF YOUR NOT EXPERANCED WITH GAS APP. GET A PRO TO WORK ON IT.
Posted on Jan 04, 2009
How much will a lid switch cost for a roper washer serial # sm828087
If it were me, I'd first go to "Sears parts" and find the model number and part number of the part you need on their free diagram.
Then, I'd got to e-bay and type in that part number and see what that part would cost. I have often done this myself.
Be blessed.
Apr 21, 2013 | Roper Washing Machines
Will not spin out any water after the final cycle
If the cycle is interupted before the final cycle it is probably your lid switch that is defective or verify if the screws on each side of the lid are tightened properly.
Apr 17, 2013 | Roper RAS6233KQ Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Apr 09, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryers Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
