Question about Kenmore Dryers
Dryer wont turn on
Was in the middle of cycle and shut off.now won't turn back on at all
  • Kenmore Master
  • 8,220 Answers
Probably blew the duct fuse. Check filter chute for lint clog. Check fuse on blower housing.
Posted on Apr 21, 2013
  • 8 Answers
SOURCE: dryer shuts down
Probably the motor is getting too hot and the thermal overload switch is shutting it down.Usually means bad motor or dirty motor. You'll have to take it apart to see. Model # and Brand would help.
Posted on Mar 27, 2008
  • 375 Answers
SOURCE: The electric KENMORE dryer shuts off in the middle of the cycle
Check the outlet pipe - it is likely to be blocked. Also clean the lint trap and check the pipe for kinks
Posted on Jul 25, 2009
  • 2006 Answers
SOURCE: Dryer timer won't shut off
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Posted on Jun 09, 2011
heatman101
  • 43501 Answers
SOURCE: Dryer won't heat up &
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Jul 04, 2011
heatman101
  • 43501 Answers
SOURCE: My dryer is tumbling & blowing & all the
heatman101
Posted on Sep 11, 2011
Steam valve won't shut off
If the water sprays after the dry cycle has completed and you have to physically have to turn the tap off, then you need to replace the water inlet valve on the unit. Here is a link to the valve.
Oct 20, 2012 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Dryer was in cycle and shut off and will not turn back on. I turned the cycle off and tried to restart and it still will no go on. This is a new dryer, only 3 weeks old.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 27, 2011 | Whirlpool WED4900XW Dryer
My dryer shut off in the middle of a cycle and now won't turn back on. What could be wrong with it? I have checked all my breakers so its not a problem with my electric.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Kenmore Dryers
Dryer stopped in middle of cycle and won't start now. Looking at all the fuses and switches and they work fine. I'm thinking it's the drive motor. Can that be the problem and it there anyway to...
heatman101
May 15, 2011 | Dryers
Dryers Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
