Question about LG LP120CED Thru-Wall/Window Air Conditioner
Lg ptac error code ch03 how to fix - LG LP120CED Thru-Wall/Window Air Conditioner
3 Suggested Answers
SOURCE: LG air conditioner model LG LP1210BXR
Well it needs to be fix by a professional, so if you or someone you know are good at tinkering go for it. It as a sensor problem at the evaporator.
Posted on Aug 03, 2010
hvac1960
  • 2133 Answers
SOURCE: getting error code ch03, brand new unit just put
Remote controller comms error. Check wired correctly, if so check dipswitch in RC. Set to Sg for 1 unit, or Gr for group then reset power.
Posted on Jan 09, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
What is code 67 on a LG PTAC
Hi Jason, The link below is a web page, Click the 4th down for an LG Ductless HVAC & PTAC Error Codes manual.....
https://www.google.com.au/search?q=LG+PTAC&oq=LG+PTAC&aqs=chrome..69i57j69i61&sourceid=chrome&ie=UTF-8#q=LG+PTAC+error+codes
Code 67 ODU fan motor not rotating or proving rotation. Verify fan motor plugged in correctly & fan rotates freely. This can be a failed motor, failed board or motor could have failed and caused board failure as well. Verify 310V DC on motor wires separated by empty terminals on plug with motor plugged in, 0V DC = failed PCB, 310V DC = likely failed motor. Next step: Unplug motor and manually spin the fan (keep it spinning): on same wires you just tested, 0V DC indicates motor failed and caused board failure. 14-30V DC indicates a good motor
Mar 31, 2016 | LG Heating & Cooling
I have a LG LP150HED-Y8 AC, A CH CODE LIGHT CAME ON HOW DO I FIX THIS?
Low pressure switch will shut down right after starting when it is low on freon. A small amount of freon will get it started but when the compressor starts it moves freon from the low line to the high
Jul 28, 2015 | LG PTAC LP150HED Thru-Wall/Window Air...
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Troubleshoot ptac units
If this is a heat pump unit, the defrost thermostat may be stuck closed
Dec 17, 2013 | Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Error e8
I don't see a error code E8 listed.. I take it your tried unplugging unit for at least 30 minutes then reconnecting unit. Could be a bad controller or display. If unit hasn't been serviced in a long time.. it should be checked for proper coolant levels and leaks.
You can find the service manual here...
files.totalhomesupply.com/data/LG/PTAC/LP123CD3Aservice.pdf
Nov 16, 2011 | LG LP123CD3A Air Conditioner
Getting error code ch03, brand new unit just put it in 30min ago
Jan 06, 2011 | LG LP123CD3A Air Conditioner
Jul 21, 2010 | LG Heating & Cooling
LG LP120CED Thru-Wall/Window Air Conditioner Logo
494 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
