Question about Plumbing
I have a pentax cam 50 with smart head. The smart head housing sprung a leak and won't start whenn the pressure drops like it usually does. I patched the hole with epoxy and hard plastic and allow
The pump is a pentax Cam 50/00 domestic water pump half horse power. It is connected to the house via 3/4" pipe. The source supply is a 1000gl tank The pump uses a smart head How do I prime this unit? Is the smart head damaged? I went out for a few hours and when I returned the water pressure in the taps was very low so I went to turn on the pump but the switch was allready on. I went to the unit and press the red reset button. which I usually do if it shuts off for what ever reason. this is when I saw the leak in the smart head housing.
Healeyman
  • 1198 Answers
SOURCE: pump 30/50lbs pumps up to 50 shuts off pressure drops to 32lbs
Look for a place in the pipe from the pump to the house where an air pocket could form. That will fool the pump.
Posted on Apr 05, 2009
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
  • 553 Answers
SOURCE: Onga Pump FM .450 switching on and off although no
I'm afraid I don't have enough information to answer your question but this link should help you to solve the problem. http://www.inspectapedia.com/water/watertank.htm
Posted on Mar 28, 2010
Testimonial: "Thank you for taking the trouble appreciated. regards Michael Meechan"
  • 349 Answers
SOURCE: when adding air to a pressure water pump ,i
Sounds like the bladder is gone or inproper air pressure in water storage tank.
Bladder goes bad check it out with step 1
1-
One way to check for sure with everything hooked up. The air valve on top of the tank if pressed you will get water out of the valve which should be only air. This will let you know it should replaced.
If Tank bladder is low in air and not water coming out.
2-If it checks ok put an air gauge to tank to check the air pressure, with a standard 40 gal tank you will have 28 psi of air in tank for it to function properly.
Posted on May 22, 2010
SOURCE: New onga JS120 pump worked fine for 4 months
a number of possibilities like insufficient pressure in the bell or pressure leak 'or pump motor dying
but i'd be looking at a warranty claim
Posted on Sep 01, 2010
Pentax smart head loosing pressure and has no leaks
Sounds like it is ready for a rebuild.
May 04, 2014 | Plumbing
Tip
Removing Whole House Filters
Frequently whole house filters can be very difficult to remove. The canisters become almost impossible to loosen, even after pressing the pressure relief valve and using a housing wrench. The most common reasons for this are the housing was put back on with the housing wrench, debris in the housing threads and a bad pressure relief valve.
http://i.fixya.neth2oservices.jpg
How to remove a stuck filter housing.
1. Turn off the incoming water.
2. By-Pass the Softener
3. Go to the nearest cold water faucet, open it and let the water run until pressure drops significantly.
4. Turn the water off at outlet of filter (If housing has shutoff on top off head, turn this off now).
5. Press and hold the pressure relief button to relieve pressure further.
6. Use filter wrench to unscrew housing (If it still won't loosen repeat steps 2-5).
7. After removing, clean housing thoroughly, make sure threads are clean on filter bowl and housing head. Lubricate threads of housing and head with plumbers faucet lube or silicone.
8. Clean and lubricate the O-Ring (replace the O-ring every couple years or if housing leaks after screwing back on). It helps to flip the O-Ring over a couple times per year.
9. Replace the cartridge filter and screw the housing back on.
10. Turn the incoming water on slowly while holding the pressure relief button down until all air is purged.
11. Open outlet and let water run to cold water faucet until all air is purged.
12. Put softener back in service.
IMPORTANT! Only tighten the filter housing by HAND!
NEVER use the housing wrench to tighten the housing.
I hope these tips help you with the angst of removing stubborn filter housings.
RJ
on May 30, 2011 | Culligan Under Sink Water Filter
Pentax smart head
Check the pressure switch. Be sure you have enough water available. Check for a leak. What are you pumping. Is it pumping. I am not familiar with this pump so I am just listing some points to check. If it is a submersible well pump it can develop a lot of pressure.
Nov 29, 2013 | Plumbing
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Oil pressure dropping
Brake Booster Gone?
Apr 13, 2017 | 2004 Dodge Dakota
How do you change the filter to a culligan water softener
Here are instruction to remove the filter housing. This is from my tips posting. Culligan filter housings are just Pentek/Pentair water filter housings and these tips apply to virtually any filter housing.
h2oservices.jpgl76w9ont156vs3p099e2rqu+8nt56e+fbm9ldnps+cnj57dmpqamzqoj3nqs4doe4cr7sqwf8acoamtivyaikaaaaasuvork5cyii=
RJ
Sep 29, 2011 | Culligan Sediment Water Filter
I have a 1987 gmc suburban and the oil pressure gauge at start up reads about 35 to 40 but after driving a while will drop to 15 is oil pressure switch bad
It depends on your mileage. It's normal for the pressure to read high on start up and then drop some but your numbers are a little low on start up, usually on the high side of 40-45.You could check your pressure with another guage and see if it reads any different. If it does then you should change yours. But if your mileage is running on the high side of 200,000 then it's probably wear and tear. I would be inclined to try a heavier oil, 15-40 or 20-50. This should bring the pressure up and help with lubrication. You could also add something like Lucas to your oil to help with lubrication and pressure. It's also possible the oil pump is wearing out but unless the mileage is below 150,000 it likely won't do much good and a new pump won't like the heavier oil.
If you are unsure of the mileage you could do a compression check. If it's 100 or under the engine is worn.There is still life in it as long as the numbers are close together but it is time to start thinking about the next step.
Jun 12, 2011 | 1987 GMC Suburban
E420 mersedes 200,000 miles lifters are ticking
Yes, I think it's time. Oil pressure is created at the cam brgs. good luck.
Jul 06, 2009 | 1997 Lincoln Continental
Need new driver for vista/pentax optio 50 digital camera
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Jan 03, 2009 | Pentax Optio 60 Digital Camera
Plumbing Logo
316 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
