Question about Air Tools & Compressors
Adjust pressure on Stogermatic MDV11R
How to adjust cut in and cut out Pressures
3 Suggested Answers
  • 1388 Answers
SOURCE: how do i adjust air pressure cut out
Square d recommends that the pressure switch be adjusted to specifications of the particular switch (which is sold in pressure ranges preset at the factory). The switch will be erratic it adjusted out of the factory setting range.
From Square D: (adjust the desired cut-in pressure first, then cut-out)
Cut-in: The large spring controls the cut-in pressure. To make adjustments, turn the nut clockwise (compressing the spring) to raise the cut-in point or counterclockwise to lower the point of cut-in.
Cut-out: The small spring is the differential adjustment and controls the cut-out pressure. To raise the cut-out pressure turn the small nut clockwise (more differential); to lower the cut-out pressure turn counterclockwise.
Posted on Sep 24, 2010
SOURCE: how to adjust cut in pressure on husky 60 gallon
what is the pressure switch model number, most of them have a nut with a spring under them, just turn the nut to adjust the pressure
Posted on Oct 21, 2012
Bostitch CPACK300 Motor won't cut off!
First; most repair centers, mine included, are reluctant to instruct users on how to adjust compressor settings because of the dangers of setting levels to high and risking tank ruptures. 15 to 20 psi is considered explosive pressures so when you are dealing with 135 to 150 psi or higher, you have to be able to understand and respect the dangers.
Second; if your compressor was working properly and now isn't and no one changed the setting of the pressure switch, it is more likely you need to replace the switch. If the spring or other mechanisms that controls the pressure the switch turns the motor off and on are damaged or broken they need to be replaced.
Lastly; at your own risk, most pressure switches have directions inside the cover on how to adjust the cut-in and cut-out pressures. I have never seen one that requires special tools, usually a screw driver or nut drive will turn the adjustment screw. When adjusting the screw, turn the screw in half turn steps and cycle the motor at least twice between adjustments to check where the switch is cutting in and out. If your switch does in fact require a special tool you will have to see if it is something the repair center can sell you or take/ship the compressor to them for repair.
Oct 08, 2012 | Stanley Bostitch CPACK300 3-Tool Finish &...
Tip
Well Pressure Switch Adjustment Water Well Problems
1fa4b10.jpgIf you have a water well to supply your water needs, then you also have a well pump is some form and a well pressure switch that controls the water well pump and the pressures that it turns on and off at. Making the adjustments to this switch can be confusing, I will try to take away some of the confusion for you. There are many types of well pressure switches made. I will describe the adjustment of the most common type of switch and you can possibly translate from there if you have a different type of well pump pressure switch.
  1. Turn off the power to the well pump before making any adjustments. The blue flash from the arc when you short out the power is scary and leaves you seeing stars for a time.
  2. Drain all of the water pressure from the system and check that you have air pressure in your well pump pressure tank. If you intend to set the cut in of the pump at 30 PSI then make sure there is 28 PSI in the air part of the tank. Always 2 PSI less than your cut in pressure.
  3. Start the pump, run water, and then observe the pressures as the pump starts and stops. Remove power when adjusting to avoid the blue flash…you are working in close proximity to the electrical contacts of the switch.
  4. To raise the cut in pressure turn the taller center nut down to increase the spring pressure. This will start the pump at a higher pressure. To lower the start pressure turn the nut up or counter clockwise.
  5. To change the differential pressure, the difference between the start and stop pressures, you need to adjust the smaller nut that is on the side of the pressure switch. Turning this nut down will increase the differential pressure and likewise turning this nut counter clockwise or up will lower the differential pressure.
This process can take some time, but it will be worth it to have your pump and water system operating efficiently. You also can set the well water pressures to your liking.
This is a basic guide to help you fine tune your water well pump and your well pump pressure tank, along with your water pump pressure switch, so that they all work together to give you a good stable supply of well water.
http://www.fixya.com/support/r3689163-water_problems_pump_problems
http://www.fixya.com/support/r3690698-pump_problems_water_tank
http://www.fixya.com/support/r3690937-pump_problems_pressure_switch
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
on Dec 22, 2009 | Plumbing
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
I had a water line bust. After fixing the leak, I lost water pressure. Someone tried to fix the problem and now we have little to no water flow. I have to pumps . The smaller pump that feeds the house is...
The nut on the larger spring in the pump pressure switch: Usually the larger nut in the pump pressure control switch adjusts the pump cut-on ("cut-in") AND pump cut-off pressures simultaneously. This is the left-hand spring (and nut) in our photo. That means that whatever the gap is between the cut-on pressure and the cut-off pressure, that gap is maintained, but the entire operating range of the pump is raised or lowered. Turning the large nut clockwise RAISES BOTH the cut-on and cut-off pressures. So turning the large nut clockwise shifts the whole operating pressure range of the pump UP to HIGHER pressures.
Conversely, turning the large nut counter-clockwise will lower the whole pump operating range. This is the simplest adjustment to make.
Photo (left) courtesy of a reader.
The nut atop the smaller spring in the pump pressure switch: this nut is used to narrow or widen the gap between the pump cut-on and pump cut-off pressures. This is the right-hand spring (and nut) in our photo).
Turning the small nut clockwise (tighter) will RAISE the CUT-OFF pressure, and vice versa, loosening or turning the nut counter-clockwise will lower the cut-off pressure. Watch out! If you loosen this nut too much you can set the cut-off pressure below the cut-on pressure and the pump will turn on and run forever (or until it burns up.)
Which nut to turn in the pump pressure switch control, and which direction to turn it, are usually visible on a label inside the pressure switch cover. Above we show photos of a common Square D water pump pressure control switch (Schneider Electric) and the label with pump control adjustment details. [Click to enlarge].
Here are Example Pump Pressure Switch Adjustment Instructions from Square -D Understanding how pump pressure control switches work and which way to turn which of the two nuts in the control can be confusing.
On a Square-D Pumptrol® 9013FSF-2 pump pressure switch, for example, Square D tells us that we
  • Turn the Range Nut #1 (the larger spring and nut) clockwise (to the right or "down") to raise [both] cut-on and cut-off pressures. This is "tightening the nut down" against the spring. ("Rightie-tightie, leftie-loosie" as Mara Gieseke says to her kids). Thanks to reader Rise for this clarification.
    In other words, adjusting the pressure on this spring shifts the whole operating range of the switch up or down, but keeps the difference between cut-in and cut-out the same, whatever it happens to be (typically it's about 20 psi from the factory.)
    If you want the pump to turn ON (cut-in) sooner
    , that is, at a higher water pressure, turn the nut clockwise or "tighter".
    If you want the water pump to turn ON (cut-in) later, that is, at a lower water pressure, turn the nut counterclockwise or "looser".
  • Turn the Differential Nut #2 (the smaller spring and nut) clockwise to raise the cut-out pressure.
    If you want the water pump to turn OFF (cut out or cut-off) at a higher water pressure, turn this nut clockwise or "tighter".
    If you want the water pump to turn OFF (cut out or cut-off) at a lower water pressure, turn this nut counter clockwise or "looser"
    Here is why the small nut is called the "Differential"
Keep reading at LINK
Nov 03, 2010 | Flotec TC2151 P2 Well Pump Pressure Switch
How do i adjust air pressure cut out
Sep 24, 2010 | Square D 9013FHG14J52M1X Air Compressor...
How do I adjust shut off pressure on an Ingersoll Rand T30 2340? Right now it shuts off at 175psi and I would like it around 125. Thanks!!
The best way to go about the task of adjusting the pressure switch is to remove the cover to switch and note the brand/model number. Sometimes instruction are under cover of switch. With switch information, look for mfg. instructions. You will most likely see one or two springs with lock nuts. Do not turn them yet. Most pressure switches are sold with factory adjustment and are sold in pressure ranges. For two stage compressors as yours, the pressure is usually factory set at much higher (150-175) pressures than single stage which is usually about 120 -125. If you change the pressure setting it will also change the differential cut on pressure. The factory will actually use different springs to achieve desired pressures and are color coded. There are too many different brands of switches to recommend how to change pressure setting. You may discover that you can only change the pressure just a small amount (+or -15-20psi ). If you find the information about your switch, make sure that you count the turns exactly so that you can return to factory settings if things go wrong. You can extend the life of the comperssor by lowering the pressure as more amperage /heat is produced to achieve higher pressures. Good luck
Sep 22, 2010 | Ingersoll Air Tools & Compressors
My compressor does not reach more than 30 psi on tank pressures why ?
hi there,
there are certain reason,try to adjust your pressure switch to as certain pressure you want,doing this refers to service manual on adjusting cut out and cut in pressure.there is adjusting screw on a box, mounted on the compressor tank.another factor for not reaching the set up pressure is lost compression observe on this is, a mechanical malfunction of worn out piston ring.if this a reason replace piston ring this should be done by certified
mechnic.have a nice day dont gorget to fix my rate,thanks a lot.
May 06, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
A dash lite on my 2009 hyundai sonata came on while was driving. if you can tell me what it is TPMS
stands for Tire Pressure Monitor System= TPMS. check all tire pressures (when cold if possible) and adjust them according to the tire pressure sticker on the drivers door jamb,glove box,another door jamb or center console compartment(inside).even check the spare tire pressure. the lite comes on to tell you that either 1 or more tires is considerably lower or higher in pressure than the rest. once u adjust the pressures correctly,look in the owners manual as to how to reset/shut off the light. on alot of cars if u drive the car for awhile the light will reset and go off .hope this helps.
Aug 31, 2009 | 2009 Hyundai Sonata
How to test a pressure sensor switch on a air compressor
Hi, W/D here.
To accurately test a switch, it has to be removed from the compressor and tested by raising the pressure and lowering it with air supplied from a known, good regulator. The trip pressures are then noted and adjusted.
The quick and dirty way of "getting close enough" is a little different. Start the compressor, and when it gets to your desired cutoff pressure, pull the plug. Adjust the HP spring untill the contacts trip out. Now, with the compressor still unplugged, drain the pressure off of the tank until you reach your desired cut in pressure, and close the valve. Adjust either the LP cut in or the differential pressure adjustment to set the cut in pressure. The contacts will pull in. If you adjust the cut in pressure with the diff pressure setting, the cut out pressure has to be challenged and set again. Whichever method you follow, you always need to check the upper and lower settings after each adjustment.
Best regards, --W/D--
Aug 13, 2009 | Dewalt D55153R Reconditioned 1.1 HP...
Air Tools & Compressors Logo
489 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
