Question about Whirlpool Dryers
Electeric dryer model # seds800mqo
Dryer will run tumble but timer does not advance and there is no heat inside dryer to dry clothes
  • 686 Answers
Could be thermal fuse or bad heat element
Posted on Mar 12, 2009
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
MY KENMORE DRYER IS TUMBLEING BUT IT WONT DRY M CLOTHS
Clogged Vent
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me
Oct 04, 2010 | Kenmore 73952 Gas Dryer
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Tumble dryer will not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
Aug 19, 2009 | Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Dryer will not turn off
May 20, 2009 | Dryers
My Amana Model NDG5800AWW dryer has ceased to dry clothes dependably. The Only setting that still sort of works is HIGH timed drying, and this heats up to what used to be the "delicate" setting....
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Sep 22, 2008 | Amana Dryers
Open Questions:
Dryers Logo
109 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
