Question about Drills
My variable speed hammer drill, Bosch CSB420 E, only works when it held close to horizontal. I am suspecting the switch, part number 2.607.200.091 what do you think?
  • bob_benne43
    bob_benne43 Apr 23, 2013
    The grommet on the mains cable had split, which put a lot of strain on the cable where it entered the case, causing it to wear internally. The damaged section of mains cable was removed and the drill is now working again.
SOURCE: Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: my drill bit doesn't remain secure in the chuck of my drill.
grind bits shank in a triangle to let the drill chuck get a better hold of bit but be carfule because this also takes away the drills ability to slip if it hits something solid.
Posted on Apr 15, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch Hammer drill GSB 16 RE doesn't work every time I press trigger
Check the brushes. the switch may have a short. Also, check the wiring from the switch, making sure there is no loose connections to the field. Definitely fixable. Lemme know Please rate me
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
Variable speed not working
The switch is bad. The part number is 2-610-998-107.
Jul 28, 2012 | Bosch 1031VSR 75 Amp 38Inch Drill
The variable speed function is controlled by the switch. If you only have off and full on, the only fix is to replace the switch (Bosch Part Number 2607202013).
Mar 14, 2012 | Bosch 23618 18V Cordless Impactor...
I have a Bosch 1/2"
Sounds as though you are on the right track. I would take it apart, and see if the trigger could have some dirt or other material causing it to stick, or is it worn to the point that it needs to be replaced. Good luck!
May 30, 2017 | Bosch Tools 8.0 Amp Corded Hammer Drill,...
My 1199vsr hammerdrill from Bosch will not start. A couple months ago, I lost variable speed (ran at full rpm or nothing). Noticed a lot of comments on line about this model not starting. Wondering if...
It could possibly be that your brushes (Bosch part number 1617000525) are worn down to where the drill won't work any more. Take the two screws out of the back of the handle and remove the housing cover to check them. More likely your switch (Bosch part number 2607200918) has gone bad. If you lost the variable speed a while ago that was a sign the switch was already breaking down. Also located inside the housing cover, you can check for burnt wires or melted plastic around the switch but it is possible the switch is bad without having any visible problems outside. Fairly easy to replace, just make sure you connect the four wires to their proper contacts.
Feb 09, 2011 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Variable speed doesn't work on Milwaukee Magnum hammer drill
how new is the tool. Give me the serial number and I will come up with a solution, also what is the switch number you bought. Let me know.
Dec 31, 2009 | Milwaukee Drills
I have a bosch rotary hammer 11245evs and it was working when i put it away in its case, now it will not hammer. Drills ok. larry
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Apr 16, 2009 | Bosch 11241EVS SDS-Max Rotary Hammer
Switch
try looking here. http://www.toolpartsdirect.com
Dec 09, 2008 | Bosch Tools 8.0 Amp Corded Hammer Drill,...
Drills Logo
117 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
