Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
My lawn mower keeps fouling plugs
Black soot on plugs and coming out of exhaust
  • 708 Answers
Your choke is stuck
Posted on Nov 18, 2017
3 Suggested Answers
MOTORWIZJ
  • 1358 Answers
SOURCE: I have no rpm's mower only runs slow. plugs foul
CARB NEEDS TO BE REBUILT. FLOAT IS STUCK.. AND CHANGE OIL AFTER REPAIR OIL WILL HAVE GAS IN IT AND IT WILL JUNK THE MOTOR IN NO TIME ... VOTE !
Posted on May 20, 2010
  • 152 Answers
SOURCE: oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
Posted on May 25, 2010
What is causing the spark plug to foul out with black carbon
check for oil gas mixture or its bad rings
Jul 02, 2014 | Garden
Keeps fouling plugs
3 things are the main causes of black soot. 1 not enough air, check air filter. 2 running too rich, lean out the carb. there will be 2 screws on the carb 1 to increase idle speed and 1 for air mixture. While running turn the mixture screw in until it sputters then back it out 1 turn. 3 bad timing. If the mower hits a rock or branch the shear pin can get creased and change the timing(it is to protect the crankshaft from breaking) Here is a link to a youtube video showing how to change the shear pin.
Aug 09, 2013 | Briggs & Stratton Garden
WHY IS THERE DRY BLACK SOOT ON NISSAN SENTRA 1996 CAR STUTTERS AND LOSES FOR SO IT EVENTUALLY TURNS OFF
Black soot coming from the exhaust would be excessive fuel.
The list includes injectors, fuel pressure regulator, fouled plugs, faulty coil, dirty air filter, and so on.
Jul 06, 2012 | 1996 Nissan Sentra
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
Black smoke from exhaust, rough idle, black soot on plugs
signs of a bad fuel pressure regulator-- the vehicle will run rough, the engine will not start ( usually in the mornings,) many times engine starts but stalls shortly after starting. a bad regulator can result in fouled plugs. replacement is only cure. 1- black soot on plugs-2-black smoke from tailpipe-3- running rough-4- stalling, good-day! repost if need be.
Aug 10, 2011 | 1994 Suzuki Sidekick
My Troy Bilt self propelled lawn mower keeps fouling spark plug out after one use. Why?
Hi , it can often be something as simple as the engine needing a oil change as oil looses viscosity/thins with use ( use correct grade ), replace or clean the oil filter and a good service or something more complex which requires a full engine stripdown like worn piston ring/oil scraper ring causing oil to flow up the cylinder walls and fouling the combustion chamber or oil leaking up through the valve stem oil seals , also storing the machine tilted can cause oil to collect in the chamber or petrol to leak into the sump causing the oil to thin.
Hope this helps , please rate accordingly
Aug 31, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Toro SR4 Running problem when hot
It can be quite a things - a blocked air filter or a blocked exhaust. To clean the exhaust, unbolt it from the manifold, hold it vertical and hit on the side until no more soot comes out. Changing the air filter should be pretty straightforward. If the spark plug bottom end is black then you have the fuel mixture too rich and you should lessen the flow of fuel.
Apr 07, 2009 | Garden
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
66 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
Daryl Gleaton
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
