Question about Wolff Sunquest 16se Tanning Bed
Tanning bed fusees keep blowing
On my tanning bed 3 lights would not work changed out all 16 bulbs now same ones still wont work and now it blowes the fusees
4 Suggested Answers
SOURCE: Where do I find replacement trim profile for my Sunquest Pro 16 SE tanning bed
Ebay has several:http://compare.ebay.com/like/350311266168?_lwgsi=y&ltyp=AllFixedPriceItemTypes&var=sbar
Posted on Mar 02, 2012
SOURCE: need info on changing fan motor on sunvision tanning bed
Sunquest repair manuel -
https://docs.google.com/viewer?a=v&q=cache:RHuta0rhh0UJ:www.wolfftanningbed.com/files/Sunvision%2520Pro%252024S%2520Tanning%2520Manual.pdf+&hl=en&gl=us&pid=bl&srcid=ADGEESiOZAyvaJoGk2XbMLNiN6HBrbcakHM2K0Ueegni817TYN8RJZmcoxwgkvEhbTnez0fQXKeYfAagL-vGcQOZe-_Lz1A8lISeW2omXte5lo7_wf0N6Ksg9heMx9RvHP7NvzHekFW_&sig=AHIEtbTIgYvCR-poN4KvkaVWUdCqD8mjDA&pli=1
  • 43 Answers
SOURCE: just purchased bed. 5 lamps
Have a trained technician to check the voltage going to the bed. If all bulbs / ballasts have same problem, this may be the problem. You may need a Buck/Booster.
Posted on Feb 10, 2013
650 Bandit S high beam stopped working changed bulb but blew that one, there is burning across the back of bulb any ideas?
Hi, Tez if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
P.S. the bottom link is a free service manual with a wiring diagram in the last chapter.
Why are my bulbs blowing
Headlight Bulb Keeps Blowing
Headlight bulb keeps blowing please help me its expensive
http://www.manualdoautomovel.com.br/areatecnica/manuais_de_motos/manuais_de_motos/manual_de_servicos_gsf650_s_2004.pdf
Jul 25, 2016 | Suzuki Motorcycles
Why does my tanning bed keep blowing fuses
Check the tanning bed for how much electricity it is supposed to use. In the US, most outlets are 15 amp, and if your tanning bed uses more than that, it will blow fuses.
Mar 19, 2016 | Health & Beauty
Sunquest pro 16 se
You may have a wire burned out going to that set of ballasts/bulbs. Have a trained technician to check and repair this.
Feb 08, 2013 | Wolff Sunquest Pro 24RS 220 Volts
My 2002 ford ranger running lights and instrument panel dont work
12V power passes through 15A fuse 33 (the one that keeps blowing?) in the battery junction box and on to the main light switch. When the main light switch is set to PARK, 12 volts is routed via the BRN lead to the park filaments of the dual park/turn lamps. These lights remain on when the headlight switch is turned to HEAD.
The main light switch gets its 12V input from 7.5A fuse 11 in the central junction box and the same 15A fuse (33) identified above. When the main light switch is set to PARK, 12 volts is routed via the BRN lead to the instrument panel dimming module and module output is applied to the panel illuminating lamps.These lights remain on when the headlight switch is turned to HEAD.
The input to fuse 33 is hot all the time so should read 12V. If you read 12V at the TAN/WHT connection with the fuse out, something is definitely not right. I'm sure you have noted that the fuse is common to the non-functioning circuits you mentioned.
Sep 14, 2012 | Cars & Trucks
Just purchased bed. 5 lamps not lighting and 1 on canopy blew immediately after turning on. replaced lamps, replaced starters and holders. still have the same issue and have tried 2 more lamps in the one...
Jul 04, 2011 | Wolff Sunvision Pro 24S Tanning Bed
2002 Isuzu axiom cluster lights and tail lights out
Don't try a higher fuse , it just makes things worse by adding extra burn to the problem.. First make a test lamp with a 21w bulb ( indicator size) .You now have a bulb with two wires attached , insert the "test bulb" across where the fuse should be.
When you switch on the circuit concerned it will glow BRIGHT as it is getting a POS (+) and a NEG (-) ie blowing the fuse (short circuit) in the fuse box and therefore a BRIGHT bulb.
As you disconnect and eliminate or disturb the problem the bulb will immediately glow DULL ( in series contact now) and no longer a short circuit . As you check the circuits the illumination will change and, your on the money ! Let's know how you get on , Good luck
Mar 05, 2010 | 2002 Isuzu Axiom
Fuse keeps blowing for front and rear side lights, also no fog lights on rear, but one front fog light working. everytime i change fuse then switch side lights on fuse blows, also dial/speedo lights not...
Sounds to me that there has been somehow a mistake in wiring. Was the car involved in an accident? I think what is happening is thatwhen you turn the light on the +12vdc go right to grond and pops the fuse. Solution is pull the side bulbs, turn the lights on then plug the bulbs back in. When the fuse blows then that is the bulb that has the short. ( not the bulb but its wiring ).
Good luck
Dec 07, 2009 | Tablets & eReaders
Why does my fuse keep blowing for my tail lights in my 96 plymouth breeze ?Every time I put fuse in it cut the lights on the fuse blows?
The fuse keeps blowing out because there is a short circuit. Check the tailight sockets for corosion. Is there a tow package wiring installed?
Jul 26, 2009 | 1996 Plymouth Breeze
Wolff Sunquest 16se Tanning Bed Logo
44 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
