Laptop wont power on when battery is full, how do i fix this?
Power indicator flashes orange after a few seconds
  • 4 Answers
Im sure its just a glitch but it might help to plug it in anyway or just get a new laptop!
Posted on Apr 21, 2013
worldvet
  • 859 Answers
SOURCE: Flashing amber battery light
Sure, this just mean your are in charging mode, but your battery is at full charge. Should your battery need charging and in charging mode the lights would be green most likely.
Regards,
Worldvet
Please don't forget to rate our solutions as fixed if we answered your questions or fixed your problem.
Posted on Jul 13, 2008
SOURCE: laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Posted on Jul 14, 2008
chrlygrn
  • 149 Answers
SOURCE: Dell Inspiron 5150 won't boot
have u checked the ram and made sure its functioning properly
Posted on Nov 11, 2008
  • 3940 Answers
SOURCE: Battery Light Flashes Orange and Green
The LED sequence indicates a failure in the battery. (Like one cell has low charge) As long as the overall battery output meets the minimum for system operation, the battery will work.
The average lifespan for a Portable battery is about 500 discharge/recharge cycles (1 to 2 years) anything after that is a bonus
Replace the battery, issue will go away
Posted on Nov 18, 2008
frenzy19
  • 258 Answers
SOURCE: Flashing lightning bolt on Compaq C300
i think the battery is depleted so the power supply can no longer charge the battery
Posted on Dec 09, 2008
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
Lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
Feb 01, 2012 | Lenovo G550 Notebook
I have an Acer 6920 and just yesterday I went to go turn it on with the power supply plugged in and connected to the outlet and the light near the power button flashed orange and my laptop wont turn on....
Sounds like a malfunction in your power supply. I would suggest contacting Acer support and informing yourself about the warranty on your device.
Don't forget to rate this comment - give me thumbs up if you liked this advice!
Mar 13, 2011 | Computers & Internet
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Dell inspiron 1100 wont stay on
Normally the battery light will rapidly flash orange if the battery is defective. It will alternate between orange and green if it is too hot to charge. Or it will either flash orange or be a steady orange if the battery is low or completely discharged. Based on this and the fact that you cannot get it to stay on for more than 7 seconds, I would have to say that you need to recharge the battery by plugging the laptop into an AC outlet. After all, it can't run without the juice.
Apr 14, 2009 | Dell Inspiron 1100 Notebook
BATTERY LIGHT FLASHES ORANGE
hi,
if you have tried both batteries with the same laptop and they are giving you the same error code, then it could very well be a motherboard problem, both the batteries cannot be bad, what you can do is try these batteries on some other compatible laptop model to check if they work fine there. Also try swapping the AC adapter as in both case you might be using the same Ac adapter, try using some other good known AC adapter as well.
Further queries are welcome
If you find my solution helpfull please do rate me
Feb 20, 2009 | Dell Inspiron B130 Notebook
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Take out the battery. that hapened on my inspiron 3800
Nov 11, 2008 | Computers & Internet
Toshiba laptop
good notion...that flashing orange suggests that even though your battery shows good, the mo' board, is not agreeing..
good luck on that..
Mar 08, 2008 | Toshiba Satellite 5105-S501 Notebook
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
