Question about Pentair Kreepy Krauly Inground Automatic Cleaner
Pool shark gets stuck on steps - Pentair Kreepy Krauly Inground Automatic Cleaner
I lent my tiger shark to my sister who has a kidney shaped pool, mine is rectangle. Is any reprogramming required since the pool shapes are different?
No. The unit 'learns' the pool based upon time recorded in the horizontal and vertical positions while cleaning. It will work, although perhaps not as well as in a rectangle-shaped pool, without any further action than dropping it in and powering it up.
John
Sep 05, 2011 | Aqua Vac Tiger Shark
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Jul 23, 2011 | Aqua Vac Tiger Shark
My Kreepy has a Starfish seal on it. It is being used in a pebble tec pool. I bought it new less than a year ago. Here are my problems...The Kreepy is getting stuck by my stairs (they are more like...
If the cleaner is getting stuck on objects (steps, ladder, corners, benches, etc), you need to remove the dive float restrictor and install a wall climb adjuster. It is part number K12065. Anyone that sells Pentair products should have one. This will keep your pool cleaner from becoming stuck. It might also help with the seal problem, but that is most likely something caught in the flapper. Check to be sure that the pool cleaners getting proper flow and that the flapper is clear of debris.
Jul 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
Kreepy bull shark gets stuck in the corners and stains (dark brown/black) the pool where it is stuck.
There are several things that you can do to prevent these pool cleaners from sticking at steps and corners. First, your return line water flow might be positioned incorrectly to force the cleaner toward the corners. Check for this and use the eyeball diverter valve to redirect the water flow if necessary. Make sure that your automatic regulator valve is installed properly and free of debris. Make sure that you have proper hose balance (the cleaner should set at a 45 degree angle to the pool bottom). Adjust the hose weights if necessary. You may need to add a wall climb restrictor or a ladder guard. If none of these correct the problem, consider adding the Thruster, which aids in random pattern coverage by automatically repositioning the hose to help free the cleaner from obstacles.
Apr 14, 2011 | Universal Kreepy Krauly In-Ground Pool...
Recently bought a bull shark creepy from Mica Benoni, and although it does clean the pool ( when it is is facing down), it climbs the walls ( sometimes and falls over onto its back and stays there the...
I have the same problem as well. There is nothing obstructing the the kreepy from sucking. This seems to be a general problem with the bull shark. I have gone to the pool places and without me telling them about my problem with the kreepy they told me what the problem is with the bull shark. My friend has the same problem with his. Mabe there is someone that work for kreepy crawly that knows how to solve this problem.
Jan 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
My tiger shark pool cleaner will run for about 30 sec. then shut off. how can i fix this problem?
The pool cleaners impeller may be clogged or jammed with debris. Check and clean if necessary. The brush rollers or drive tracks could also be stuck. Check for debris and remove. It is most likely one of these problems if it is shutting off after only seconds of running. If these don't seem to be the problem, I would check your power source.
Aug 18, 2010 | Aqua Vac Tiger Shark
My tiger shark pool cleaner spends a lot of time at the top of the water line. How can I adjust it so it does not climb so far?
the tiger shark is designed to climb but you can adjust the weights to keep it down. check out http://www.aquavacsystems.com/Weights-and-Floats_ep_31-1.html
for more info and specs of your unit. good luck
The Pool Tech
Jul 02, 2010 | Aqua Vac Tiger Shark
How can I keep my Tiger Shark from sticking to the main drains in my inground pool.
Decrease suction on main drain and increase suction to cleaner.
Jan 15, 2010 | Aqua Vac Tiger Shark
Baracuda gets stuck
Usually this can be fixed by redirecting thr returns in the pool down the wall or anywhere that will break up any currents in the pool.
Dec 30, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Tiger shark will not move
The motor that drives it forward and back is seperate from the fan and is defective unless your stuck on the main drain the motor unit needs replacing.
Mar 14, 2009 | AquaVac Tigershark 2 Commercial Vac with...
Pentair Kreepy Krauly Inground Automatic Cleaner Logo
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
