Question about Apple iPod nano
My ipod lost it's screen
If I'm lucky and get it in the right mode Ican hear my music. I can't determine the battery level or info on the songs. Do I need to replace it?
I have the same problem with mine, If you get an answer that works please email me.
Bunnydwf@aol.com
Posted on Mar 12, 2009
How do I delete songs from my ipod?
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer. The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod. Open up iTunes by double clicking on the "iTunes" icon. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings. Manually Delete Music Connect your iPod to your computer. Open up iTunes. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK." Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your song.
Apr 10, 2013 | Apple Audio Players & Recorders
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
How do i delete music from my ipod
carefully follow the steps below:
Automatically Delete Music
  1. Open up iTunes by double clicking on the "iTunes" icon.
  2. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen.
  3. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song.
  4. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list.
  5. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings.
  1. Connect your iPod to your computer.
  2. Open up iTunes.
  3. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK."
  4. Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed.
  5. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen.
  6. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your
I hope this will help you out.
Good luck.
Jul 05, 2010 | Apple iPod nano 5th Generation
My ipod nano froze while i was listening to my music so i restarted it by holding the center button and the menu button. now all it shows is the apple on my screen. when i press play, i can hear my music...
Try going in itunes, right clicking on the song, and click create AAC version. The song may be in the wrong format which is why it won't finish playing it. Hope this helps!
Feb 20, 2010 | Apple iPod nano 5th Generation
No soundon acid music studion
there are a couple of level meters in the lower right corner (if they are visible). one is the master volume control (far right) and the other is the preview track level.
the preview track level determines what volume level the added loop or audio track will be. if its at the bottom of the meter you wont hear anything.
also under Options (top menu) you will see a selection for Preferences. Please check the setting in those tab views.
other than that I guess i would need more info.
if you are just starting with acid, i suggest you look at acidplanet.com
Jan 29, 2010 | Sony Acid Music Studio 7 Full Version for...
My ipod will play a song, but only the music will come through and not the voice
This is rather unusual as it appears that you are playing your music in 'karaoke' mode on your iPod (but you should still slightly hear the vocals).
Try setting another music equalizer mode such as 'POP' or 'ROCK'.
Dec 27, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
I pod nano looses songs and scrambles albums.
This may have something to do with how the ipod is reading the names of the songs.
Hook your ipod up to iTunes and when the summary screen comes up uncheck the "automatically sync music"
This will put it in Manage Music Manually mode.
click the music folder and inspect the song titles.
if a son has something in the name such a a number before the name title change the song name to remove the numeral. see if it comes back in order.
as for losing songs, the ipod will remove songs when you sync if it doesn;t find it in your playlist.
this may be whats going on.
Apr 11, 2009 | Apple iPod nano 3rd Generation
I have bought an apple ipod shuffle in december from uk. i have downloaded the songs into ipod from computer. i am able to hear the songs in ipod from computer. i have fully charged the ipod untill the...
Green and ORANGE? orange indicates the iPod is searching for music.
UNDERSTAND this- when you play music in the iTunes app., you are hearing the music in your computer not the iPod.
1) Install the latest iTunes application.
2) Do a restore
3) sync your iPod
Jan 22, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Waht to delete some songs from ipod
delete them within I tunes programme
Aug 23, 2008 | Computers & Internet
Transferring music
http://docs.info.apple.com/article.html?artnum=60940
Dec 17, 2007 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
