Question about hotmail.com
How to connect to ip camera - hotmail.com
  • 826 Answers
You PC should have the IP address in order to connect with the ip camera which is also connected to DVR and Router.
Given is the link of the video with which you will be able to connect with IP camera.
http://www.youtube.com/watch?v=54_qUbEqOe0
For further assistance you can visit our website http://www.vtechsquad.com
or can call us on our toll free no. for further technical assistance i.e 877-974-4669
Posted on Apr 22, 2013
How to convert local ip camera addresses to ip addresses to connect from internet
depend on what brand and type of the ip camera that you use.
in order to be able to access from internet:
- you need to use a router that connect to a switch and the camera
- the router must have UPnP Feature & Port forwarding.
- just in case your public ip address is dynamic, you will also need a ddns for redirection.
The basic concept is, you have to configure the network setting of the camera according to the router as a gateway.
usually, in the network setting, you will find a http port number.
change this number from default ( 80 ) to another number from 0 to 65535 ( example 50010 or 40000 , you can choose freely, it's recommended to use port above 50000 )
then find the portforwarding function in your router, then set the port number to the ip address of the ip camera.
if it's successfull, you can directly access the camera from the internet by entering your public ip address and the port number on your browser.
for example : http://itcomm-streets.viewnetcam.com:50001 << my ip camera demo unit.
Jul 02, 2012 | Android Apps
Not showing the network ip address. Note i changed it from 192... to 172... and now trying to go back to the 192.168... network
Set the camera to "automatically obtain an IP-address".
Connect the camera, via an Ethernet network cable, to a router.
The router will supply a valid IP-address to the camera; much simpler than trying to "manually" set an IP-address, network-mask, and gateway IP-address.
Dec 08, 2009 | Veo Observer Network Camera
I am trying to get my IP camera to work
1. connected the camera in the ethernet port of the belkin router
2. know the ip address of the ip camera
3. access the camera from the computer by using typing in the ip address of the camera for example 192.168.2.x
Nov 29, 2009 | Belkin (F5D72304F5D7000) Router
How do i install ip cameras so that i can see them over the internet? I have a dvr connected to my 2wire modem and I do have static ips
You need to find out what ports your ip cameras use, and then setup port forwarding on your router. If you have 1 box that controls all the cameras, you just need to forward port 80 traffic to that box. If you have multiple cameras with NO main junction box, you will need to go into the setup on each camera, and specify a port to use.
Then in the router, set up port forwarding to forward each different port, to the camera it goes with. Then when you want to see the camera from home you would type the ip address in the browser, then a colon, then the port number --> IPADDRESS:81
Sep 12, 2009 | 2wire HomePortal 1100 Router...
How to watch IP Camera on internet by using DSL-2640T??
let me give you few suggestions and then you can take it from there.
firstly IP camera is just what its name says..it needs a fixed IP address it may be local as in your lan where it is working or a IP address from ISP.
Now when you connect it behind router... it is essentially a camera connected to LAN.
now the problem is DYNDNS.com will give access to your router since that is connected to dynamic IP addressing. However Ip camera is behind router and to access it you need to open proper protocol and port in router .consult your router manual for doing that.
with your current setup that is the only solution. however you can connect Ip camera directly to ISP line and then use dyndns as in case of router. though i dont know how feasible that will be for you.you have not mentioned IP camera model so cant help with specific details.
Aug 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can't find IP Address
Helo,
You want to find the localserver ip address U go to cmd- and then type ipconfig .U want the internet ip address u go to this site ip-detail
Apr 03, 2009 | Sony SNC-RZ30N Network Camera
IP camera keeps resets itself
Hi
I have a pretty good knowledge of these cameras as I have 5 around my house.....
IP address resets are likely caused by the default address being loaded (192.168.0.99) and the box is not checked to reset the IP on reboot. You have two options.....
Using IP surveillence, open the camera settings. You will be prompted that the recording will stop, just press OK. Once you get to the settings window, you should see your list of cameras and the config screen for the one that is highlighted. Pick the camera you want to change the setting for and go to the tab where you can assign the IP address and gateway. Type in the IP address you want it to use. Uncheck the box that says 'reset IP on reboot'. That box is at the top. Hit apply. Once you do that, cycle the power on the unit leaving it off for at least 10 seconds. When the camera reboots, type in the new IP and you should be able to view it. (sometimes the camera will default on that IP if your router is using 192.168.0.1 and DHCP for computers that has that IP in it's range of assignments of IPs. Telling the camera which one to use and telling it to not reset on reboot will make the new IP stay in the camera.)
Your second option is to use the Installation Wizard or IE, find the camera either by typing in the IP for the camera in IE with the http:// or linking to the device with the installation wizard. If you follow the same procedure of assigning the IP and unchecking the box on reboot like described earlier, this should cure your problem. You do NOT want the IP resetting on reboot unless the camera will not link to your home router (likely causes for this is the IP range the router uses, say 192.168.1.1 like most belkin or linksys routers use, does not cover the IP range of the camera in it's DHCP server.
What I found best was to buy a junk router, set it's DHCP IP range to cover 192.168.0.99, set the camera, save it, kill the cameras power, connect it to the router you plan to use, then start the camera back up. Make sure whatever IP address you use on the camera is one covered by the DHCP server list on the router. ie: camera is set to 192.168.2.2 and the router assigns IPs from 192.168.2.2 through192.168.2.254. If your router only assigns IPS from 192.168.2.100 through 192.168.2.200 and the IP on the camera is 192.168.2.2, you won't be able to connect to it.
Hope this helps
May 19, 2008 | D-Link DCS-3220 Network Camera
Need to change ip address for my camera
How is your webcam connected to your network? Is it connected to your PC or your router?
If it is connected to your router, go into the router settings and see if the router reassigned a new ip address to the camera. If you set the router up for DHCP, it will automatically assign IP addresses to all devices that are connected to it, as long as the individual devices are also set to dynamic IP addressing. Your router is set up for the 1.0 network, so your pc is most likely 1.2, while your router port connecting to your home network is 1.1.
Another thing you can do is make sure your webcam is turned on and go into 'My Network Places', then click on workgroup computers. See if the webcam is listed there.
Apr 11, 2008 | Toshiba IK-WB01A Network Camera
Problem with IP Surveillance configuration
Can you view the stream in IE or IP surveillence or is it that you hit the camera in IE, the sign in box shows up (cause you put in a pasword), you put in the password, and it cannot connect and says retry.
Possible problems.....
The IP you are typing in is really not the IP of the camera (comes from the box being checked that says 'reset the IP on reboot') Use the installation Wizard to find the camera and it's IP.
Your firewall is blocking the stream. Try disabling it and reconnecting.
Your cameras IP is not in the range of the DHCP server of the router it's connected to. Review your router's DHCP list to see if the camera IP is in that range.
The password on the camera is corrupt. You will need to hard reset the camera and reset it back up from scratch to connect.
Worst comes to worse, you can always just hard reset the camera and start over.
Apr 05, 2008 | D-Link DCS-3220 Network Camera
hotmail.com Logo
113 people viewed this question
Top hotmail.com Computers & Internet Experts
David Payne
David Payne
Mike
Domagoj Car
Are you a hotmail.com Computer and Internet Expert? Answer questions, earn points and help others
