Question about Diesel Case 1370,1470,1570 Tractor Piston & Sleeve
1370 fuel tank removal
How do I take tank off tractor 1370 case
2 Suggested Answers
  • 8 Answers
SOURCE: Have a 1370 Case tractor,
Clutch is maybe shot. Maybe low on tranny fluid. Make sure brakes aren't locked on. Wiggle the shifter levers as it maynot be engaging. This tractor if I am correct is an old tractor. Case tractors of this era never were very dependable as far as I am concerned. It might be the reason the tractor was sold in the first place. Hope it helps
Posted on Apr 09, 2011
Case 7130 Tractor stas running then quits
I had a close to that problem and decided the fuel was the problem,So I added a electric fuel pump between the fuel tank and the manual fuel pump,,but also check the fuel line between the fuel pump and the fuel tank,for it may plugged with dirt or the manual fuel maybe to weak to the job ,so I added electric fuel and the no more problem with air locks or no fuel to keep the tractor running.
Jun 04, 2014 | The Times Case Corporation Tractors...
Where are the transmission filters located on a 1370 case tractor
The filters are located behind the engine under the clutch housing. It is an hour glass shape cover about 1 1/2 inch thick with six 3/8 bolts .Be careful it is heavy , will loose about 2 gallons oil.
May 19, 2014 | Diesel Case 1370,1470,1570 Tractor Piston...
1370 case fuel tank removal
It is as hard as it looks. one plate on each side of tank, slips out the back. If you can get unstuck from the dirt.
Mar 24, 2014 | Diesel Case 1370,1470,1570 Tractor Piston...
Adjust clutch pto
yes there is. The feathering valve spring is broke.
Aug 24, 2013 | Diesel Case 1370,1470,1570 Tractor Piston...
My rear hydraulics on my 1979 case 1370 tractor
Sounds like you have a hydraulic cylinder bypass problem on the disc
May 09, 2012 | Diesel Case 1370,1470,1570 Tractor Piston...
Have a 1370 Case tractor, that has plowed 30 acres without problems, now it runs but doesn't move
Apr 09, 2011 | Diesel Case 1370,1470,1570 Tractor Piston...
Case 1370 agri king runs wont move
have you checked all of the linkage and lines? filters? get pressure test on hydraulic system to see if pump is weak
Apr 11, 2009 | Diesel Case 1370,1470,1570 Tractor Piston...
Diesel Case 1370,1470,1570 Tractor Piston & Sleeve Logo
67 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Ted Maxwell
Are you a Diesel Garden Expert? Answer questions, earn points and help others
