Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I replace the power cord on the DC07 Dyson vacuum
  • Dyson Master
  • 18,411 Answers
Here is a video that will help you
Posted on Apr 21, 2013
  • 3 Answers
SOURCE: Dyson DC07
your better bar is miss alined put a felt tab (for chair legs thier sticky) on the side if the bar near the belt on the inside end re put in the better bar no more noise
Posted on Feb 29, 2008
reddevil6
  • 1673 Answers
SOURCE: comparison on 2 vacuum's
Sorry I really can't give you an honest answer. I don't care for the Dyson vacuum and service for them in alot of areas is hard to find as alot of servicers don't work on them.
Posted on Jan 14, 2009
SOURCE: How do I replace the cord on my Dyson DC07 Animal
To replace the cord, remove the screw on the front plate just above the on off switch. This is held on with tabs, so carefully use a butter knife or screwdriver to pry the plate off. Once the plate is off, remove the slide in tabe from the white plastic protectors and remove them. Slide the tabs of the new cord into the protectors and then push the protectors back on the vacuum tabs. Replace the plate and screw. NOTE: I did test the vacuum to make sure it would turn on before replacing the plate and screws.
GOOD LUCK! Sheila
Posted on Oct 20, 2009
Samyfam
  • 379 Answers
SOURCE: Replace power cord on Dyson DC07
The following link will take you to an article on how to change the motor on a DC07. Look at photos 4, 5 and 6 which shows how to disconnect the power cord.
http://www.dysonmedic.com/DC07%20Folder/DC07%20Motor%20change.html
Reassemble by reversing dissassembly instructions.
Posted on Jan 01, 2010
  • 231 Answers
SOURCE: how do you remove the electrical cord for a dyson
remove the cover right above the canister. there is a couple of screws in the front holding it in. i think they are T15 torx. that will give you access to your switches and your cord
Posted on Jan 03, 2010
Dyson stopped working
There are three things that "stop" (no noise anymore) a DC07 working. I will list them in order of the most common to least common faults.
1) The motor is burnt out. Caused by over filling and not cleaning the filter regularly. You must replace the post motor filter when getting the motor replaced
2) The power cord has failed. This can usually be seen by visually inspecting the cord for damage.
3) The on/off switch has failed.
All of these faults should be repaired by a licensed sparky for safety reasons.
Keith @ Dyson Repairs North Shore Auckland
Jun 22, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson dc07 won't turn on.
Hello, this is Ava with Think Crucial.
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfuntioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest to refer to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 12, 2012 | Vacuums
Dyson vacuum power cord
You may purchase your Dyson Power Cord from us using the link provided below.
Dyson DC07 DC14 DC17 DC18 DC25 Replacement Power Cord Part 905449 02
Ava B.
May 01, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Power cord chewed off by dog needs replacing who can do it and how much does it cost.. Animal dc07
Sorry to hear about your DC07 cord. Do not try to use the cleaner with the cord in a damaged condition. Please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to advise you on the best course of action.
Kind regards,
Jack
Dyson Customer Service
Jul 23, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vacuum won't turn on
Check if light is coming on, if it is there maybe something caught under the switch. what I think it will be, you have streched the cord braking it inside, fix or replace cord.
May 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you remove the electrical cord for a dyson
Jan 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dec 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07
First, check your outlet for power...plug something else in. Then, inspect the cord and check the power switch. You can use a multimeter to test across the power plug of the vacuum in the ohms position. Turn the switch off and on. If it does not change readings...the switch or cord is bad. If it does, it might be the motor.
Jan 02, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
60 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
