Question about Akai LCT3285TA 32 in. LCD Television
Restore sound how do i restore the sound picture is fine
TV had moisture get in. TV status- Turns on fine, sound is fine, but no picture, just a white line horizontal across middle of screen
Field scan drive has gone, This requires your local repair shop.
Give them a call first and describe the problem.
Moisture causes problems with the circuit board long after it has dried out.
There may be other problems only evident when the picture is restored.
Best weigh up the cost of a repair V a new TV( with 5 year guarantee - advised)
Feb 12, 2011 | Toshiba 20AF41 20" TV
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
Nov 01, 2010 | Sylvania SRD3900 DVD Player/VCR
RESTORE SOUND TO MY COMPUTER
hi you just need to restore the system back to the date where sound was working fine , you may follow the process
click on start then go to all programs them accessoris, then system tools select system restore and restore your system back to the date where your system was working fine , (this process if if you have win xp .
for vista and win 7
type system restore in start search and restore the system back to the date.
Hope this resolves the issue .
Sep 16, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
No Picture, Only sound
You need to tell the PS3 that you are now using the new video method. It is still trying to output video on the yellow cable, not the component. If you go to settings>video and tell it to use component, and then switch the cables real quick, it should work.
An easier solution is to do a backup from the system menu, then a "restore" (quick restore is fine), and then power it off, hook up the new cable, and it will detect the video method when it turns on for the "first" time (since the restore).
You do have component input on your TV, and that is the input you are on when you are trying this, yes?
Jul 22, 2008 | Sony Playstation 3 (PS3) Console
Tried turning on my Sony and no picture no sound, just a black screen
Sony is known for having problems with the picture tube. Sometimes it will blink on and off. also bad connections on the main board. A CRT restorer will sometimes help with picture tube problems but this must be done by a tech that has one.
Apr 11, 2008 | Televison & Video
DVD no picture but sound ok lg v8824w
hi there, had same problem, try turning on the player then holding the stop button on the remote for five seconds.this should restore the video picture
Jan 19, 2008 | Televison & Video
Sony kp48s35 (rear projection tv)
You need to have the crt px tubes checked for heater to cathode shorts, a picture tube restorer is needed to refurbish one or all three tubes to restore balance to tubes. Sony has a px muting built into the circuitry to save the tubes from being destroyed. If one tube is conducting more than one of the other two the imbalance is detected and causes picture (px) muting... blinking on & off the picture. Most repair shops have this crt restorer on hand.
Jun 07, 2007 | Sony KP-48S35 48" Rear Projection...
There is no sound when i play a dvd
Can you give more infomation, like what program your using?
Jul 26, 2006 | Acer Aspire 1804WSMi Notebook
Akai LCT3285TA 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
