Laptop wont boot up, black screen, has power
- battery has been dead, been using laptop with power plugged in. - started having trouble getting screen to turn back on after it "sleep" (turns black after being idle) myfix:>> shut power off, wait a few minutes, turn it back on. **worked, for a moment - screen stopped turning on completely myfix:>> followed instructions from several websites: - took battery off - unplugged power - pressed on power button for a few seconds - plugged back in without battery - pressed button **worked a couple of times. - stopped working, but still has power. (i think) CURRENT STATE: 1. plugged in to power source: - 1st front indicator light turns solid white, remaining 5 stays off 2. power button pushed: - "caps lock" light flashes once - 1st & 2nd indicator lights turns solid white, remaining 4 stays off - "booting up" sound starts but stops, as if it just got lazy - can hear low sound, as if there's something going on inside, but it's not pulling thru. ==pls help me fix this, or atleast know what i can do about this issue im having. i tried to be as detailed as i can describing the situation im dealing with, but if there's anything that doesn't make sense, please feel free to ask me questions. ==thank you for taking your time reading this, and advance thank you for your help. ==have a great day... =)
  • sharon abustan Apr 21, 2013
    thank you for ur response, and i did forget to mention make n model... its toshiba satellite L64D-S4056. i actually adjusted power settings before just as u had suggested, which worked ffor a little bit,... and now, im unable to get it to boot up. i get nothing but a black screen, 2 solid white little indicator lights. even iwhen i try hooking it up to a different monitor, pressing f5 to adjust monitor thingie, but nothing. is it game over for me and this laptop? :(
  • 7,627 Answers
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Posted on Apr 21, 2013
    thank you for ur response, and i did forget to mention make n model... its toshiba satellite L64D-S4056. i actually adjusted power settings before just as u had suggested, which worked ffor a little bit,... and now, im unable to get it to boot up. i get nothing but a black screen, 2 solid white little indicator lights. even iwhen i try hooking it up to a different monitor, pressing f5 to adjust monitor thingie, but nothing. is it game over for me and this laptop? :( - (reposted, mistakenly posted up there initially.. but this is where i intended to put this in reply to max carson's post.)
tparsenault
  • 170 Answers
SOURCE: HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Posted on Feb 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: my hp laptop will not boot up
Check the power supply for power. Replace if necessary. Also check the motherboard for proper operation. If no fans come on or only come on for a few seconds then you have a bad motherboard
Posted on Feb 14, 2009
jmgldsmth
  • 1889 Answers
SOURCE: on my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Posted on Apr 21, 2009
benwabnick
  • 2404 Answers
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Posted on Nov 30, 2009
  • 177 Answers
SOURCE: Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Posted on Mar 07, 2010
Could a dead bios battery result in a blank black screen?
The EEPROM is not the copy of the BIOS used to boot the OS or effect settings. The EEPROM defaults get copied into CMOS memory (hence why it is called the CMOS battery). So if the CMOS battery is dead then there is nothing to energize the CMOS chip to retain its values. That means on every boot you will get the defaults loaded from EEPROM. It will not cause black screen.
you do not give much info, does machine come on and runs but screen is black, or computer dose not start at all, more detail would help, press the helpful button and RE POST with more info
Jan 31, 2016 | Computers & Internet
W701 ds black screen
It should work without a battery just a good power supply plugged in.
Jan 09, 2016 | IBM Lenovo ThinkPad W701ds 25003CU...
Black screen wont start up
Unplug the main battery, and press the power button for 15 seconds. Plug in the battery, plug in the battery charger and press the power button. If your laptop does not start, then there is something wrong with the motherboard (it is dead).
Feb 20, 2014 | Computers & Internet
My samsung n150 mini, was working very well.suddenly, the screen turns into black and no sound of the processor. Screen and battery flashlight indicates that they dont work.what is happening?
Does the laptop start up with power adaptor plugged in?
If yes then battery may be dead, you can check for a replacement online, battery model may be AA-PB2VC6B but check the battery label to ensure you note the correct battery model.
If the laptop does not boot with the power adaptor inserted, remove the battery and try booting with just power supply inserted and see if laptop boots.
If still not booting then it is a hardware fault, either battery, power adaptor or internal part possibly motherboard, you will have to contact Samsung for repair.
Good Luck
Jan 10, 2013 | Computers & Internet
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
Will not boot... black screen?
Try removing the battery completely and powering it up on AC power. Sometimes a dead battery (even if you're plugged in to AC) will stall a boot-up in its tracks. If this doesn't help, please reply back and let me know if anything changed.
Jul 09, 2009 | IBM ThinkPad T40 2373 Notebook
Black screen only.
1. Windows reinstall thru CD ( crashed graphic drivers )
2. screen itself faulty
Jun 07, 2008 | Toshiba Satellite P35-S611 Notebook
DELL INSPIRON 1000
Try the following:
1. Try to boot the notebook with both battery and adaptor attached.
2. Try to boot with ONLY the battery.
3. Try to boot with ONLY the adapter.
If you can't boot with only the adapter, the adapter has died. If you can't boot with only the battery, the battery is dead.
But as stated above, make sure your battery is sufficiently charged.
In case of a dead battery or adapter, check whether the device is still under warranty. Contact HP if so.
Let me know what you found out.
Greetings,
DarkNeogen
Jan 24, 2008 | Dell Inspiron 1000 Notebook
HP Pavilion DV2036e Wont Boot
similar cases,,,,,,,,won't boot,,,,,1.) if with black display; please check your ram memory, if you have 2 take out it all and replace it one by one, try to boot one at a time,,2.) if with black display and the pan start functioning maybe your cpu is dead, try to switch it to another computer with thesame socket and voltage,if this computer won't boot also,maybe you got the answer.........hope to help
Dec 24, 2007 | HP Pavillion ZV6000 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
