Question about Kenmore HE2 Plus Front Load Washer
Not getting cold water at all, only steaming hot water is coming out
A few days ago my father in law installed the washer in replace of our old washer that broke. Before the old washer broke the cold water worked fine on it. Now we have this really nice washer but only steaming hot water is filling the tub thing, not cold. The washer is brand new so I don't know why it wouldn't work. Maybe he set it up wrong? I'm not really sure but we need this washer to work because we've been having to spend around 50$ a week just to do clothes at a laundrymat. Please answer asap.. Thanks :)
    New Friend:
    Problem Solver:
  • 9 Answers
Look at the water knob one will say hot one will say cold . on the one that says cold there is two arrows one will say open one will say shut turn the knob closer and closer to the arrow that says open. turn it till you cannot turn it any more . now your washer is most likely to work if not look at creaters glide if still does not work cheak water pipes and coneshoins and if still does not work ask someone at the store and if STILL does not work return to store and buy a new one i hope your washer works.
Posted on Jun 22, 2013
  • 883 Answers
SOURCE: Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Posted on Jul 17, 2007
the dr
  • 447 Answers
SOURCE: kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Posted on Dec 02, 2007
rpbuice
  • 161 Answers
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Posted on Jan 08, 2009
SOURCE: won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Posted on Apr 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Slow Cold Water Fill
There is possibly a filter screen in the hoses as well as the water valve.Check the hoses for screens.Occasionally the water valve will deteriorate inside and must be replaced.
I am on a water well and have the same problem. This weekend I installed a inline filter purchased from Lowes. It has stopped the sand and silt problem. You will have to buy one extra water hose to do this yourself.
Posted on Jul 16, 2009
Outdoor motion sensor
Try checking the timer setting, father in law had this problem with his and that was the solution.
May 09, 2013 | Home
Whirlpool LSL9345eq0
Hi i dont think it is a train smash, Whirlpool normally have a cartridge fuse in the wiring harness. You will need to open the top panel and look inside the cover and you will see the fuse assembly. Open it and confirm the faulty fuse. Replace and test. Make sure no water is present on retest.
Jun 23, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Renault Clio Campus Radio Code missing
dealer for codes need vin and proof of ownership ----dont know why the last few request for renault are popping up this is an 8 yr old post
Jul 23, 2008 | Car Audio & Video
Cold Water runs constantly even if the washer is off
you will need to replace fill valve where hoses connect probably has sand in valve especially if screens have been removed remove screws in rear of console lift and roll console back disconnect wire to lid switch remove clips om right and left rear corners cabinet lifts off disconnect hoses and wires 1 screw usually holds valve in postion
May 01, 2008 | Whirlpool Ultimate Care II GSW9650LW Top...
RIVAL Crock Pot 3350 - Replacement of Cooking Pot
same, it was given to me as a gift from my aunt a very long time ago, just last night the liner broke. Where can i go to find a replacement liner?
Mar 05, 2008 | Rival 33511 5-Quart
6 months old. Now no water will fill drum! Works as normal but no water!
Hurlewan Your washer is still under manufacturer's warranty which is one full year. If it has Kenmore's name on it you do not need proof of purchase. The only thing you need is your mother-in-law's home phone number at time of purchase because Sears keeps all their records based on phone numbers. Good luck, Gendos post back....
Jun 27, 2007 | Kenmore 43142 Front Load Washer
Cold water line
replace water valve and fill hoses
Mar 21, 2007 | Whirlpool LTE5243D Top Load Stacked...
Kenmore HE2 Plus Front Load Washer Logo
188 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
