Question about Raybestos 2000 Plymouth Neon Coil Spring
2000 Plymouth Neon ignition stuck again! I have replaced the ignition control module and it still isn't working? PLEASE help!
Key stuck in ingnition. Will not turn to start car!
  • 31 Answers
Try lifting the shift lever while turning the key. You can also try holding the outside ring of the ignition switch in while turnig the key.
Posted on Apr 23, 2013
2000 ply. neon wont shift into overdrive
Plymouth transmission wont shift into overdrive Questions ...
www.fixya.com > Forum > Tags > transmission wont shift into overdrive
Plymouth transmission wont shift into overdrive related problems. Ask your Plymouth transmission wont shift into ... My 2000 plymouth neon is stuck in park.
Dodge Neon Questions - my neon will not go into overdrive ...
www.cargurus.com > Questions > Dodge > Neon
CarGurusSep 14, 2012 - my neon will not go into overdrive, it stays at 3500 rpms on highways - my neon does not ... 2003 Dodge Neon won't shift out of park 5 answers.
part2 replace the shift solenoid and speed switches in a ...
? 7:15
https://www.youtube.com/watch?v=2ETvtt8fcr4
Sep 10, 2009 - Uploaded by Sean Conley
Dodge Automatic Transmission Removal - Duration: 11:05. ...Dodge Neon Crushed By Mud Trucks ...
Jan 25, 2016 | Cars & Trucks
2000 plymouth neon won't recognize transponder key
there is a keyless entry control module
Jan 23, 2013 | 2000 Plymouth Neon
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
HELP! My 2000 plymouth neon wont crank and no mechanic i bring it to can figure it out!!
If the headlights and dashboard lights are working but the vehicle still does not start, the ignition switch is most likely the problem. or a bad wire from switch. If your battery checks out, but the starter is still silent, it may be a faulty ignition switch. Turn the key to the on position (not all the way to start). If the red warning lights on your dash don't light up (and your battery connections are clean), the ignition switch is bad. If they do light up, turn the key to the start position. The dash warning lights should turn off at this key position (most cars). If you're not sure, turn on the headlights. When you try to start the car, the lights should either dim (a lot) or turn off completely. If they do, your ignition switch should be ok. If not, the switch will need replacement. check the wires to starter and see if you have power when car is switched on, do this first! good-day! if it cranks but does not start. check to see if spark and fuel, and check all fuses also.
Mar 21, 2012 | 2000 Plymouth Neon
I had to replace the ingetion on my a 2000 neon due to a lost key. how do i bypass the alaram system to keep the car running
If you had an ignition with a security chip key and you replaced it with an ignition that doesn't have that function (I believe it was a gray key in 2000) then your options are 1: replace the ECM or 2: Replace the ignition yet again with the correct ignition type. That security system is built into the ECM and there is no bypass. If that is an after market alarm, not common with this restriction, remove the cut off from the ignition wires or disable the alarm but cutting the power wire.
May 14, 2011 | Plymouth Neon Cars & Trucks
2000 plymouth neon...ignition locked up. Key has a computer chip in it. Will that be a dealer item and do you HAVE to replace it with another computer chip ignition switch??
Usually, if you have an alarm system, it may have locked the ignition up. If you have been seeing a security symbol on the dash, alarm going off, ect. It may be the computer ship. You may need a code. No matter, you need to call the dealership and ask them. They should be able to let you know. The ignition switch may have gone bad. If you need anything, please let me know. I am here to help you in anyway I can. Thanks for choosing FixYa and have a good evening.
Feb 23, 2011 | Computer, Chip, Cruise Control for...
2ooo plymouth neon wont start it just clicks twice rplaced battery, park neutral switch and tested starter please help
Could be the ignition switch is worn out. Not the key part but the electrical part connected to the key. It has wires coming out of it.
Nov 07, 2009 | 2000 Plymouth Neon
Key stuck in ignition
you need to rock the steering wheel back and forth as you attempt to turn the key off. some cars have a button that you have to press before you can remove the key.
Robert
Please take a moment to rate this solution.. thanks
Jan 16, 2009 | 1996 Plymouth Neon
Raybestos 2000 Plymouth Neon Coil Spring Logo
49 people viewed this question
Top Raybestos Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Raybestos Heating and Cooling Expert? Answer questions, earn points and help others
