Question about RTO Intermatic DT620CL 15 Amp Indoor Astronomic Digital Timer
Need to reset on and off times - RTO Intermatic DT620CL 15 Amp Indoor Astronomic Digital Timer
  • RTO Master
  • 5,245 Answers
Copy following link to help identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
Add comment and describe timer in detail
Posted on Apr 21, 2013
I need help resetting the date and time on my Celestron super weather station. There is a label that says 433MHZ
Hi Richard do not own one of these stations but normally you can obtain instructions on line or try to contact the manufactuer
Mar 11, 2015 | Celestron Measuring Tools & Sensors
Volvo timing marks
The timing can be reset by lining up the timing marks, but this is futile if the belt has broken or timing has jumped more than a few teeth. What are the circumstances by which you think you need to reset your timing?
Dec 10, 2013 | Cars & Trucks
Error 27
Hello.
Here's what you need to do;
Make sure the printer is powered off but connected to a power source, then press the Power button while pressing and holding the Stop/ Reset button. And turn on, press the Stop/Reset button two times while pressing and holding the Power button. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Jun 17, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How to disable alarm system. The alarm went off
okay, this alarm reset is done by turning the key on and pushing the reset button a few times, you will need to try this a few times to get the correct number of pushes,for example turn key on and quickly push 3 times and if that doesnt work retrey it and push it 4 times, take note that every time you try you need to turn key off and then on again before you push reset button,i know it can be set to 1- 2 -3 or 4 pushes to reset, this is programed at the time of install, most installer dont set it or tell you so you will need to try all four. good day.
Apr 15, 2011 | 1996 Nissan Pathfinder
Need reset code for change oil light
Hello thegoat1969: My name is Roger and I will help you. To reset the oil reminder you will need to perform the following. 1. Turn the key on engine off. 2. Press the accelerator pedal fully tree times within 5 seconds. If the CHANGE OIL SOON light flashes two times,system is resetting. 3. Turn key off,start the vehicle.If CHANGE OIL SOON light comes back on,the system did not reset,repeat the procedure. After the restart wait 10 or 15 seconds to give the lamp time to reset and go off. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Feb 16, 2011 | 2000 Chevrolet Impala
Alarm and ink buttons all orange flashing E and 3 What do i do? first time both inks low cannot replace as do not stop in the middle holding down reset button turning printer on and off
You need to reset the Printer
Clear the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jan 05, 2011 | Canon Office Equipment & Supplies
My waste ink is full. how can i remove it
you need to clean the Ink Pads out first then you need to reset the printer by following the following
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off) then turn it on again. this works. thanks.
Dec 21, 2010 | Canon PIXMA MP150 All-In-One InkJet...
The "Ink Absorer is full" error message is coming up when I want to print. How do I fix this?
You will need to reset your printer.
Try to follow these procedures to reset your printer.
and holding
move into a
Stop/Reset button 4 times, the specified number of
alternately in
button pressing
5) Turn off the printer.( it must be turned off)
Aug 31, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Reset the time
there is no reset button for the time. The stereo gets the time from the GPS antenna. If you are parked in a garage it will not work. the only thing that you usually need to cange is the daylight savings time.
Jul 10, 2008 | Pioneer AVIC-D3 Car DVD Player
RTO Intermatic DT620CL 15 Amp Indoor Astronomic Digital Timer Logo
Top RTO Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
