Question about Saws
I cant lift the lever to insert a new blade on my ERS800K ryobi saw. It appears to be jammed. How can I over come this? thanks.
Saw hasn't had a lot of use and I have changed blades once before and it worked perfectly. Probably out of guarantee by now, it is over 2 years old.
  • Ken Vaughan Apr 22, 2013
    I have given it a fair dose of CRC and even after 2 weeks it hasn;t freed up.
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
  • 31 Answers
SOURCE: RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Posted on Mar 29, 2009
lester482529
  • 226 Answers
SOURCE: PHS550B saw blade change
MOST TIMES THERE IS A ARBOR LOCKING BUTTON ON THE HOUSING NEXT TO THE BLADE HOUSING.YOU HAVE TO HOLD THIS DOWN WHILE TURNING THE BLADE SECURING NUT TO LOOSEN OR TIGHTEN THE BLADE,OR YOU CAN DO IT THE OLDFASHONED WAY FIND A VENT HOLE IN THE BLADE,STICK A SCREWDRIVER IN IT LOCK THE SCREWDRIVER IN PLACE THEN TURN THE NUT(WHILE UNPLUGED OF COURSE)HOPE THIS HELPED
Posted on May 23, 2009
SOURCE: dewalt recipr. saw keyless chuck tab used to
We had to send our saw to repair center to install new lever. Fortunately, still under warranty.
Posted on Aug 10, 2009
  • 10865 Answers
SOURCE: I bought a delta scroll saw model number 40-540,
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Posted on Sep 15, 2009
My brand new Ryobi Reciprocating Saw blade clamp will not open enough to insert a blade. Rick
You are probably trying to use old-style blades in a new saw. Go back to the store where you bought the saw and ask for the correct blades.
Nov 28, 2017 | Ryobi Saws
Saw do not lift when turned over
Is this the saw you are talking about? A compound mitre saw?
TFO 250 Ryobi
I'm assuming you cannot lift the blade up by the handle without the whole saw coming with it. That usually means that the saw is locking into place for transportation purposes. Look at the pictures below and see if the lock pin in engaged.
Apr 19, 2015 | Ryobi Saws
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
How do you insert blade?
Lift the yellow lever on the front side of the saw. Insert the blade (teeth side down). Once the blade in fully inserted, release the yellow lever.
Sep 04, 2013 | Dewalt DW304PK reciprocating saw kit with...
Mastercraft 2 in 1 flip over saw only works on one side
You have a safety lock as the table turns to table saw with an open blade.if you don't hear the click or one of the wires on the locking mechanism have come loose it will not function. Used to have one but I wore the motor out - best portable saw I have owned and I own a lot of high end saws.if anyone has a flip saw for sale let me know - pipeline@nucleus.com.
May 31, 2013 | Saws
Severe vibration with Dewalt 744S Table Saw
try it with no blade
if you have unhabitual noise and vibration,probably need to change bearing
if you do not have a bearing puller do not try to do it yourself
professionals will take 2 to 3 times less time than you do the work and if there is something else damaged, (gear damaged,) he will see it and inform you
Sep 22, 2012 | Dewalt DW744S 10" Portable Table Saw with...
How to remove broken blade stub from cordless ryobi reciprocating saw
Try spraying the clamp assy with WD40 and then gently bang the front down against the work surface whilst holding open the clamp lever.
May 16, 2012 | Ryobi 18 V Cordless Reciprocating Saw
My saw will cut for 5 seconds and then the blade stops spinning. When I back the blade out it starts again and the process is repeated. It takes a long time to cut wood this way. What's the problem? Is...
I would suspect a combination of the two! You blade probably isn't sharp and your saws brushes are probably getting worn. The brushes are made of carbon and are pushed up against the rotor by a spring. As the brush wears down the spring doesn't put as much pressure on the brushes which means it will stop working when placed under heavy load.
Aug 11, 2011 | Rotary Professional Grade 7.25 Inch...
Ryobi TS-254 blade guard does not retract when blade is lowered
Probably something jammed up inside the body of the saw where the guard retracts, like a chip of wood. I once had the same problem with my circular saw guard not retracting. Turned out there was a screw that had somehow gotten trapped in there and once that was removed, guard functions perfectly now. Definitely sort it out as soon as possible because this is very dangerous--you could make a cut, rest the saw on your leg and... earn a quick trip to the emergency room.
Aug 11, 2011 | Ryobi Saws
Saws Logo
135 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
