Question about Sewing Machines
,Does 4D Embroidery Suite workwith Windows 8?
Need a new laptop, but do not know if 4D will work with Windows 8?
abuse_this2
  • 6 Answers
SOURCE: When I try to start my 4D embroidery software for
The author is incorrect regarding all of the uses of the HASP software/drivers. In the case of the sewing/design software being at issue with this person, she is dealing with a HASP hardware dongle which is the license control mechanism of a software product which absolutely *MUST* be installed on the personal computer or they cannot use the software. At all times, when the software is used, the hardware key and the HASP software must be running and the HASP license manager must be running as a service under services.msc
For quiltin_mama:
I have been struggling with this issue for my mother as well and have not come up with a final solution but I believe ours is one of damaged dongle or erroneous registry entries. I suggest the following actions:
1) lauch services.msc (click Start -> Run -> and type services.msc <enter> in the box) and look down the list for HASPLM?.EXE (I don't recall the full name). Verify that it is set to start automatically (right click on the item, choose properties, set "Startup Type" to automatic.
2. If you are using Windows Firewall, you need to add exceptions to the firewall: Control Panel -> Windows Firewall -> Click the "Exceptions" tab at the top.
You will need to add an exception for some of the 4D software applications. Now, I don't know which ones actually talk to the HASP, so what I suggest is: Click Add to create a new exception, and then click the "Browse" button to the lower right. Navigate to c:4d embroider\ (assuming you have the default directory) and then select the first 4D***.exe you find on the list, and click done. As I recall, there are 4 of these apps and you need to do this for each of them. Down the road, if any of the other parts of the software suite fail because they can't communicate, come back here and add the *.exe to the exception list.
Next, you need to exempt certain TCP/IP ports from the control of the Windows Firewall. If you download and install the firmware update from Husqvarna's site which they say is included in the 8.1 upgrade, the very last screen of the process, after doing all the main work, it will tell you to open a specific software port. I can't remember which port that is, but as I recall it was 14xx. Run this update and write down that port.
Back to the firewall exceptions list, now create two entries for this port: the first is for TCP port of that number and the second is the UDP port for that same number. Don't worry about why, but both appear to be needed. When adding the exception to the port, there is a button at the bottom left which says "scope". Click that and make sure that the top radio button of the 3 choices is the one selected.
Second, I made an interesting discovery while searching and trying to find the port number I mention above. There is another port which is listed as the "default" port for the Alladdin HASP software/dongle we are dealing with, and that is port 475. Please add exceptions (both TCP and UDP) for that port as well.
Finally, make certain that you have the latest HASP drivers from the ! HUSQVARNA ! site for Windows Vista and then apply the various 8.x updates to the 4D Embroidery software ! IN ORDER!, starting with 8.1, then 8.2a, then the 8.2b, then the 8.3, and the second 8.3(b?). (The 8.2 version has a 1 either before or after the '2', I don't recall which, the important thing to remember is that there is a 2a and 2b version and to do the 2a version first)
As you install these updates, BE VERY CAREFULL to read any warnings. I am told that some of the updates do not work with/will break under different versions of Windows. I haven't seen this myself as I haven't run them, but a dealer told my mom that one of the updates was her problem and that the update specifically said not to install it if you had Windows version (X). Unfortunately, not have the software myself, I cannot confirm or deny this.
There you go, I hope these steps help. One other piece of information: when (re)installing the 4D software and/or the updates, disconnect the computer from the internet and shut down any antivirus, antispyware, antimalware, and firewall software you might have running. After completing the installation, be certain to *REBOOT* the computer and logging in so the AV software is running before you again connect to the internet. I hate to say it, but all it takes is a matter of seconds before a worm can find its way into an unprotected computer to infect it. A couple of years ago one of the test organizations did that with a PC and it was fully under the control of malicious people on the internet in less than 2 minutes.
Best of Luck,
Mike
Posted on Jan 08, 2010
  • 201 Answers
SOURCE: 4D color select not working
Firstly I believe you need 32-bit Vista for the Husqvarna software to work correctly. Is this what you have? You could try the "Reset Modules" button in Configure - when anything goes wrong, this is always a good place to start. Not sure on this, but I think the colour highlight only works on the Design page.
Posted on Sep 03, 2009
  • 14 Answers
SOURCE: Dongle won't work with 4D Embroidery
Unfortunately some people are having this problem when they are not properly installing the updates. It's important that when 4D is installed that you assign a particular port for your 4D dongle and always use this port when loading 4D. Have your dongle plugged in and access your configure menu. Click on Smart Update. Download updates into a file where you can find them. Follow the directions for each update. For the driver update, you must uninstall the current driver you have and then install the update for the driver. If installing the updates doesn't fix your problem, the only solution is to completely uninstall 4D and all of its components and then reinstall it. Sorry...but this has been the only way to fix it with some systems. Also, make sure your User Account Control is off before installing 4D.
Posted on Sep 10, 2009
SOURCE: I have a bouth a
I had a similiar problem, but I have the Designer SE. In Windows 7 there is an option to run it in a compability mode, so I had to set my program to run in XP 32 bit mode for the 4D software to run. I don't know if it will help, but if the software worked in XP, this should do the trick.
Posted on Dec 31, 2010
  • 474 Answers
SOURCE: I have a new computer with Windows 7. I installed
Reload the drivers for the program. If it still does the same thing, go to there web site and Down load the Patch for it.
Posted on Feb 22, 2011
Husqvarna 4D Embroidery software Dongle issues
Viking changed their website and new links. Suggest you contact Software Support for Viking at
Toll free 1.800.446.2333
Monday - Friday: 8:00 am - 4:00 pm CST
info@husqvarnaviking.com
Dec 14, 2013 | Husqvarna Designer I
Windows 8 Laptop Computer won't recognize 5D dongle or 4D dongle.
I used this link for the same problem. Download and install. Resolved my problem immediately.
http://sentinelcustomer.safenet-inc.com/DownloadNotice.aspx?dlD=8589947873
Dec 08, 2013 | Husqvarna Viking 1
I have a bouth a new computer with windows7. I have installed all my 4D Embroidery Extra and 4D Reader Writer. However I am unable to call up designs on my reader writer. Do I have to install a new...
Dec 26, 2010 | Husqvarna Designer I
My laptop which has windows 7 on it does not recognize mmy dongle
there is an update for windows 7 and dongles at the husqvarna viking website.
From Husqvarna Viking website -
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
link to latest Dongle Drivers - http://vsmsoftware.net/downloads/HASP/HASPUsersetup.exe
Husqvarna Viking - http://www.husqvarnaviking.com
If you are still unable to get it to work, visit your local authorized Husqvarna Viking dealer. Most stores have staff who are eager to help but you might want to call for an appointment
Good luck..
Feb 13, 2010 | Husqvarna Designer I
Loaded autodigitizing onto our new computer with Windows 7. Everything loaded just fine but when I try to open program it does not recognize the dongle.
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
Feb 09, 2010 | Husqvarna Designer I
I have the Husq Pro software for my #1+ machine and I bought a new computer with 64 bit. I can't get it installed. What do I do?
Good luck.
Jan 23, 2010 | Husqvarna Viking 1
I need a driver for a husquvarna 3D reader/writer card, where can I find one
Dongle issues - http://www.husqvarnaviking.com/global/8588_4197.htm
Good luck.
Dec 10, 2009 | Husqvarna Viking 1
Can't get computer and embroidery machine to connect via USB. Computer doesn't recognize embroidery machine. (Husqvarna Designer Diamond) I also have a new DELL laptop.
If your using Windows Vista, you have to have the multi user account in the off postioin. Also if you had 3D embroidery software and you upgraded to 4D software you have to be sure to uninstall the 32 bit drivers from the 3d for the 4d to work properly.
You do have to install the communication software that came with the diamond also. It won't communicate through the 3d or 4d only.
Jul 12, 2009 | Husqvarna Sewing Machines
Viking Rose can't install System 5 software
You may be able to find an old computer with Windows 95 or 98. Make sure that it also has a parallel port for the older R/W boxes.
You may also find that the 4D Embroidery package will do what you wish to do and it is under $400. 4D Embroidery Extra is the $700 package.
If you only want to put existing designs onto the card with no manipulation, you can get the Reader/Writer kit, $199 MSRP that includes Organizer which will allow you to load 1 design to your card at a time.
Unfortunately, System 5 was replaced by VIP which was replaced by 3D which was replaced by 4D. I don't think that system 5 will run on anything newer than Windows 98.
Apr 03, 2009 | Husqvarna Designer I
Sewing Machines Logo
948 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
