Question about Sewing Machines
Have a Janome 1600P-Top thread keeps breaking
  • Sewing Machines Master
  • 7,365 Answers
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Posted on Apr 24, 2013
4 Suggested Answers
SOURCE: janome 1600P
My husband and I worked for months trying to solve this problem and FINALLY we did it. I even had a YLI varigated thread in the top and Coats and Clark varigated in the bobbin. The machine Janome 1600P DB makes a beautiful stitch. This is a long posting and if you have questions I'll be happy to help if I can. together425@pennswoods.net
1) I give credit to piecemealquilts.wordpress.com for their recommendations.
Most of which I list below.
2) First of all make sure that the frame is level in all directions, side-to-side, top to bottom. That includes the table that it is setting on.
3) Bobbin tension: This is much looser than you normally have it set on. The bobbin should fall steadily to the floor. Read your machine manual to learn how to loosen the tension. Be sure to go in small increments. Don't be afraid. It also helps to use a different color thread in the bobbin than the top to see the problem. Is the bobbin properly inserted into the bobbin case. Is the bobbin case properly inserted into the machine?
4)Use the correct needle for your machine.
5) Use at least a 14 and a 16 or 18 is even better. Size 20 for specialty threads if you can get a size that large.
6) Make sure that the needle is inserted properly. My machine doesn't have a flat side so proper insertion is challenging. If you can find a straight pin small enough to fit in the eye do so as this helps to determine if the needle is in at the correct angle. The eye of my needle is left to right so I use a sturdy piece of thread, some spray starch on the thread helps it to stay straight. This makes it much easier to determine if the needle is in properly.
7) The pressure foot dial is set on 0
8) The stitch length is set on the longest stitch length. I know that you actually determine the stitch length and some people tell you to have it set on 0, but I found this to work.
9)Threading: Make sure you have the machine threaded correctly. Inoticed that when my thread was breaking that the thread in the take uplever was either out of the thread guides or had crossed each other. Also, sometimes the thread had wrapped itself around the first smallthread guide and/or the outside hole on the pretension thread guide hadwrapped around the bottom of the thread guide. When your thread breaks pull a good 12" out and then cut it off assometimes it has frayed higher up. This will help to reduce continuedbreakage and your frustration. This sounds dumb but still make sure the thread is sitting on the spool properly, that the thread spills off the spool as shown in your machine manual. I found it helpful to place a felt pad underneath the spool of thread. This was just a scrap of felt with a hole cut into it. Check the retractable thread guide which is right over your spool that it is correctly positioned and not twisted around. The thread should easily pull off the spool. I found that my machine worked better if I onlythreaded the two guide holes closest to the machine on the pretension guide.
10)Thread tension: I found that my needle tension had to be much looser than what I was used to anywhere from 1 -3.
11)The quilt: Not too tight and not too loose,too tight and needles and thread break, too loose and it's difficult to move the carriage. Can you poke a finger from the bottom and grip it from the top? I found this a little too loose, but used it as a guide. The side clamps are to keep it straight and not tight.
12)The take up rail should just barely clear the bed of the machine. I found it more accurate to check this with the machine in the middle of the quilt as opposed to one of the ends. Can you fit your fingers between the quilt and the machine bed? Yes, but barely is the answer.
13) I was able to quilt in both directions, but make sure your carriage moves freely in all directions.
14) Make sure the feed dogs are down and ready for free motion.
15) Make sure the presser foot is down and ready for sewing.
16) Check both the bobbin area and the top thread tension area for stray threads. It happens.
17) My last help was to add thread lubricant, but make sure your machine allows it. I just found out that you shouldn't use this on the spool if you have plastic tension discs. Mine are metal, but still I use this sparingly. I run a couple of lines on the spool, let it sit for a few minutes then sew. I don't repeat this for at least an hour of constant sewing.
18) Strangely this also helped, every so often I pulled straight out on both the knobs of the pretension disc and the tension disc. Don't pull the knobs off. This just released the tension of the thread. I didn't adjust it, I just pulled straight out. I didn't rethread it, just released it.
19) Finally, I did discover that I had a burr on my tension disc.How to figure this out, well it works better with two people, but one can do it. Lift up the presser foot, needle is in the highest position, then manually , slowly pull the thread through the needle, listen to the tension disc. You shouldn't hear anything. Watch the tension disc, does the check spring move down? Does it stay down then bounce back up? It shouldn't. Feel the thread as it is being pulled does it have tension on it? If the answer to these questions is yes, take it to the shop and let them fix it. It literally takes 5 mins.
I hope this helps
Posted on Jan 12, 2009
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: Janome 1600P:top thread shreds.Ihave done all
You have adjusted the tension? aligned the needle? Bobbin moves freely? Needle height is adjusted properly?
Posted on Jan 13, 2010
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
My Janome 1600 keeps breaking threads
Is the tension too tight? Are the tension discs clean? Remove bobbin case, clean it and re-thread as this may be jammed.
Apr 26, 2015 | Janome 1600P-DB Mechanical Sewing Machine
These are some causes. The thread guide has been missed so re-thread the machine. Tension is too tight. Needle is blunt or bent. Thread is getting caught on the rough edge of the spool so turn spool around. Hope this helps
Mar 09, 2014 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P skipped stitches
Normal top tension is 3-4; normal bobbin tension (iirc) is 35 grams.
I'm betting, though, that a new needle, right way around and the correct size, would solve your skipping problems.
Jan 15, 2014 | Janome 1600P-DB Mechanical Sewing Machine
I have a Janome 1600P DBX. The needle is installed correctly but the thread on top keeps breaking or skipping stitchings while free motion quilting? the quilt shop says it is not out of time. I have...
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
Apr 20, 2011 | Janome 1600P-DB Mechanical Sewing Machine
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
Top sewing thread keeps breaking
generally, this is a threading problem, but don't rule out that you may have a weak thread.
try cleaning all the guides by cutting a thread at the cotton reel and pulling it towrds the needle, and double check the tension. i hope this helps
Sep 07, 2010 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P:top thread shreds.Ihave done all fixits. top thread still breaks.
Jan 13, 2010 | Janome Sewing Machines
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
304 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
