Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
My husband ran over my daughters shirt with our Dyson DC17 animal. Now it's making this horrible load ratting noise. I've taken the head off. Clean the beater bar. The belt is in tact. No
It is still working. Just making this awful loud rattling noise. Sounds like its broken. Thanks!
  • Dyson Master
  • 1,534 Answers
First make sure there are not any of the rubber cogs missing from the belt, it may be wise to replace the belt anyway because the cogs may be worn. Make sure the brush roll does not have any play in it anywhere and that It fits tightly in the nozzle housing without any play. If there is any play or wiggle that will cause it to move.
Posted on Nov 06, 2013
  • 134 Answers
SOURCE: beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Posted on Mar 08, 2009
SOURCE: The beater bar makes a horrible clunking noise when I turn it on
I just came from the repair shop. There is a recurring problem with a bearing coming out. Repair guy turned it on & said that loud noise is a symptom of that exact problem. This is a warranty item, as is the belt & on/off switch. Dyson comes with a 5 year warranty, so call their 800 number to get the name & address of an authorized repair shop.
Posted on Mar 28, 2009
  • 7 Answers
SOURCE: I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Posted on Apr 18, 2009
ukvacfan
  • 328 Answers
SOURCE: I ran over a shoe lace and now it is making a loud rattling noise
The All Floors model has a protective belt clutch system and the rattling sound means the clutch has slipped. This would have to be repaired officially by a Dyson repairer.
Posted on Jun 19, 2009
  • 78 Answers
SOURCE: Dyson Animal 07 beater bar not spinning - belt not broken
if your unit has a clutch it maybe that it is in the off position or the motor belt is broken your unit has to belts if its a clutched model
Posted on Oct 27, 2009
Riccar supralite makes a loud rattling noise like the roller is banging around
If the noise is not something in the brush roll or the brush roll bearings or shaft is damaged the impeller may have something stuck in it or it may be broken.
May 15, 2014 | Riccar Vacuums
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loud noise coming from cyclonic cap
sounds like you'v lost a rubber seal check this diagram on the link below see if you can see anything missing
http://www.vacpartswarehouse.com/Dyson-DC24-Upright-s/3888.htm
Apr 01, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
My new bissell proheat is making noise! any advise on what to look for?
Hi Madelyn! Sorry to hear about the rattling sound. This is most unusual. You may want to have one of our Authorized Service Centers inspect your machine.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 20, 2013 | Bissell 1699 ProHeat Clear View Upright...
Sounds like the beater bar hits the front plastic makes a loud awful noise
Hi Cathy,
Your DC33's brush control is designed to make a ratcheting sound to warn you if something is jamming the brush bar. You should be able to resolve this by making sure the cleaner head is free of any obstructions, and removing any threads or hair from around the brush bar. For guidance in doing this, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc33/dc33-multi-floor/dc33-maintaining-your-dyson-machine/how-to-remove-a-blockage/from-the-brushbar/removing-debris-from-the-brushbar
This should resolve the issue, but if you're still concerned about the machine after following these steps, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 27, 2012 | Dyson DC33 Animal Bagless Upright Vacuum
Why does my DC17 Animal vacuum keep shutting off?
Hi Emmeline,
I'm sorry to hear you're having difficulties with your DC17. From what you've described, it sounds as if the thermal cutout feature is shutting the machine down to prevent overheating. If you've already tried washing the filter and are still experiencing the issue, I'd encourage you stop using the cleaner and to contact us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Nov 16, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I caught the rug in my dyson animal dc17 and now the bar doesnt work, belts fine' motor still comes on and reset doesnt work...
I'm sorry to hear you've had difficulties with your DC17. The brushbar is designed to cut out if obstructed, so although you've tried resetting it, I'd suggest taking a look at the video below to check everything is correct with the machine.
Please note, the brushbar will not run when the cleaner is standing upright, so recline it into the vacuuming position before you test it. It's also a good idea to press the brushbar on/off button twice to make sure it's not set to the 'off' position.
You might also want to run through the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=956&product=DC17-ANIMAL
If you're followed these steps and are still having issues, please get in touch with us directly so we can provide further assistance. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com.
Kind regards,
Jack
Oct 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
DC 17 horrible noise when brush engaged. A silver metal roller thing fell out the bottom.
I'm sorry to hear you're having difficulties with your DC17. Please get in touch with us so we can resolve this for you as quickly as possible - you can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Oct 21, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I've replaced the beater bar on my DC17 animal. When I turn on the vacuum and engage it, the machine makes a high pitch squeal noise and the bar will stop turning. I have replaced the belt and still...
Sorry to hear you're having difficulties with your DC17 Animal. You might find it helpful to check that the brushbar is free of threads, hair, or anything else which might be obstructing it - the easiest way to do this is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=961&product=DC17-ANIMAL
If the brushbar appears to be free of obstructions, but continues to make an unusual noise, it's probably best if you get in touch with us directly so one of our experts can provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact with you as soon as possible.
Kind regards,
Jack
Dyson Customer Service
Aug 10, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Red light comes on and there is a smell. Have not had any problems before. Help and thanks, Karen
Hi Karen,
Sorry to hear you're having difficulties with your Dyson cleaner. From what you've described, it sounds as if you may have a DC28 Animal, rather than a DC17 Animal. The on/off switch flashing is designed to warn you that there's an obstruction in the cleaner head, which may be jamming the brushbar. The easiest way to check for and remove an obstruction is to follow the simple steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1241&product=DC28-ANIMAL
Hopefully by removing any blockages from the cleaner head, you should resolve your issue. However, if you've followed these steps and are still concerned, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting over the phone with you and provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in touch with you as soon as possible.
Kind regards,
Jack
Customer Service
Aug 08, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
417 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
