Question about Electrolux Frigidaire 14.8 cu. ft. Chest Freezer FFN15M5H
How maney watts is my 15 cub feet deep freezer
What watt is it \
    New Friend:
How maney watts is my 10 cub feet deep freezer
Posted on May 29, 2013
Specs for arctic king chest freezer model w8s-185c1ws how many watts does it use
Specs don't appear to be available. Freezers are usually rated in amps. To find the watts, multiply the amps by the voltage. Would also depend on the cubic feet of the freezer as the bigger the freezer, the more amps the compressor draws.
Only thing I could find is its energy star rating.
Find and Compare Products
Jul 09, 2016 | Freezers
HOW MANY WATTS DOES A 60 LITRE CAMPING FRIDGE USE
That info will be posted on a back plate on the refrigerator.
And if you cannot find anything on the back or inside then hook up ammeter to the unit and measure the amps used after it has been running for about 15 minutes. Then using formula watts = amps times volts (115 in USA) you can arrive at the wattage of unit.
Mar 16, 2015 | Freezers
Will Freezer run overseas on a transformer?
Step Down Voltage Converters You can use this link to find a converter that should work. There are several other sites as well. You need to get a converter with enough wattage capacity to operate the freezer. I recommend you get one with a somewhat higher wattage rating than the freezer's wattage rating. For instance if the freezer is rated at 700 watts, I would get at least a 1000 watt converter. Good Luck !!! and Bon Voyage !
Mar 30, 2014 | Kenmore 7.5 cu. ft. / 212 liter Upright...
I need to know what size power inverter in watts and if they come with a car lighter plug
You won't do it. An inverter will keep a compressor running at maybe 200 or 300 watts but it won't start it up.
May 17, 2012 | Freezers
Looking for the start up surge for my kenmore freezer 253. I would like to purchase a generator and want to make sure this freezer would operate.
At the peak power usage time..compressor start up it may reack 11 amps..when calulating that it is a max of 1300 watts..so a generator of 1500 or more should work fine
When running after start up is usually about 500 watts
Gene
Aug 26, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Hi, I have a Vulcan Deep Freeze 300L with no bulb in light fixture, Can you tell me what type of bulb and wattage should I buy. Not sure if these bulbs are a special type or not. I also need a cover for...
http://www.alliedappliance.net/_vulcan_part.html
aussie aussie aussie oy oy oy
hi from sonic boom electronics sydney above is a link to volcan parts australia they should be able to help with a cover as for the globe it is 240volt 20 watt pm5 connection
take care need more help feel free to call 0416380976
Sep 29, 2010 | Vulcan Freezer EXTWARRANTY-GCO2D Extended...
Power output
Use the formula P x I = E where p is 120 volts I is amps and E is watts. On the service plate it will tell you amps. That is the fan the compressor and the light. My frig is 6.5 amps full load. that would be 120x6.5=780watts.
Nov 23, 2008 | Freezers
Electrolux Frigidaire 14.8 cu. ft. Chest Freezer FFN15M5H Logo
101 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
