Question about HP OfficeJet 6110 All-In-One InkJet Printer
Won't scan Paper put in HP all in one will not scan using the HP Scanner.
  • HP Master
  • 1,679 Answers
Hi Betty,
Try this utility and it should give you detailed information about whats missing when you try using scan option from HP Solution Center.
Click here >> HP Print and Scan Doctor
Download this utility and run the program.
If it gives any Red X on Drivers, you might have to uninstall the software and reinstall.
Click here to Download Drivers >> HP Driver Download
Regards,
Sean
Posted on Apr 22, 2013
sagarjd
  • 95 Answers
SOURCE: How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Posted on Nov 21, 2008
  • 127 Answers
SOURCE: My HP deskjet 2050 all-in-one
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
Posted on May 31, 2011
  • 97 Answers
SOURCE: My Hp 4500 printer won't
change the catridge, head of catridge is bad
Posted on Aug 14, 2011
jimmyverdade
  • 336 Answers
SOURCE: I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Posted on Oct 29, 2011
Hp c4580 on mac 10.6 won't scan
Based on the information you gave this may help:
Go to 'system preferences'
select 'print and scan'
Above the picture of the listed printer select 'scan'
Then select 'open scanner'
Follow onscreen directions from here.
Jun 08, 2012 | HP Photosmart C4580 All-in-One InkJet...
Tip
Using a paper jogger in an office
Working in an office I handle a lot of paper on a regular basis. After getting a paper jogger I can not imagine getting any work done with out it.
Using a paper jogger is very simple, all you have to do is load the paper into the bin. What the jogger does is, is it used a motor to vibrate the paper so that it squares off nice and even around the edges. This is a very simple and brilliant piece of technology it takes advantage of gravity to make the paper perfectly aligned.
I have found that work has been much more efficient since getting a paper jogger. I have been getting less paper jams in the printer and the folding machines has to redo fewer folds. Usually what happens when I don't use the machine is I have to square off the paper by bouncing it on the table but if they aren't perfect, then the folds won't be even leading to more work because I have to redo it or the printer gets jammed and I'll have to open it up to find the jam.
There are special machines that can be used to feed paper into a scanner so that when the paper goes into the scanner all the pages are scanned properly and perfectly. This has been a great tool for scanning many pages really quickly. I have been using this for scanning in my boss' hand written notes so that he can have them saved in his email in case something should happen to the physical copies.
The joggers can be a little pricey but when it comes to saving time and working more efficiently you can't really put a price on saving time.
on Dec 26, 2013 | Office Equipment & Supplies
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
Need user manual and software for a HP ScanJet 4p scanner
HI...................
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
  • LINK OF THE USER MANUAL IS GIVEN BELOW.............
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=25293&prodTypeId=15179&objectID=bps01187
  • LINK OF THE DRIVER IS GIVEN BELOW................
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=25293
Sep 23, 2011 | HP Office Equipment & Supplies
How to scan in hp scanjet g2410
First install the required drivers for the HP Scanjet G2410 Flatbed Scanner.
Simple way is to scan is use PICASA
GOTO http://picasa.google.com/
Download picasa 3.8
  1. Make sure everything is connected and turned on!
  2. Put the photo on the glass of the scanner - face down
  3. In Picasa, click 'Import'
  4. Click the arrow for the drop down list of devices. You should see your scanner listed ... select it
  5. Now you will see a screen that depends on your scanner. There should be an option to 'Preview'. Click that.
  6. You should now see your picture, there may be some settings you want to change here, but if it looks OK then
  7. Click the button to Scan
  8. When it's done scanning, you're back at the standard Picasa Import screen. Click Import all.
  9. Select a folder to put it in. I made a folder called 'Old Photos' for the first one, then, for each subsequent scanned photo, I selected that existing folder from the drop-down list.
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Scanjet G2410 Flatbed Scanner
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
The scanner won't scan when you press the button. how do i fix it?
Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Disconnect the printer from the power source. Reconnect after 10 seconds. When the printer turns on, reinsert the cartridges and load some paper. Try to scan again.
Since the scanner hardware is also used for the Copy function, can you try to make a copy and see if you encounter any problem.
May 11, 2011 | Lexmark X2670 All-In-One Printer
How can I scan my paper to the computer with the HP Photosmart C6280?
Just put the paper on the top of the scanner then cover it. After that goto the program of your scanner then open the program and click scan then wait until they could finished to scan your paper.
May 26, 2010 | HP Photosmart C6280 Printer
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
