Question about Filtrete Thermostat. 7-Day Digital Programmable Thermostat 3M-22
Replacing a janitrol hpt 18-60 with a Filtrete 3m-22
I have an electric furnace with a separeat outdoor AC unit all wired through the Janitrol HPT 18-60. There are 8 wires coming from the wall, six are being used. The yellow, green, red and orange on top match the terminals marked Y, G, R, & O, the white wire connects to the e terminal and blue wire to the c terminal. The w2 terminal was unused.as were the black and brown wires
  • Filtrete Master
  • 15,628 Answers
What is the question that you have about this? What is the make and model of the hvac unit that it is running?
Posted on May 05, 2013
Does the water heater and furnance run on gas and electric?
If the units are in a RV then yes, they both may run on gas and DC (battery power). The furnace requires gas to provide heat and DC power to run the fan. A water heater may be gas or electric, but if gas, it requires gas to heat and DC power to ignite. If the water heater is electric it requires AC power to heat.
Oct 15, 2015 | Water Water Heaters
Hi i have a wireless room thermostat i wish to fit to my potterton boiler can anyone advise me thanks
in general-
wireless thermo has 2 units - room thermo and furnace rcvr.
if thermo is battery powered no wires to connect - if not needs 24V connected - then why do they call it wireless?
rcvr connects to same 4 wires as current therm except at the furnace - 24v power and 2 control lines
I can't remember the color code except red/black is +24v/common
but I have found them messed up by "professional" installers so u need to verify before connecting or go by the terminal labeling.
Dec 09, 2014 | Water Heaters
What is a requarement for motor, do we need it to be bonding ?
Motor must be grounded with ground wire.
Some local codes require outdoor motor shell to be bonded, with a ground rod driven into ground and ground wire attached... in addition to ground wire back to panel.
Never hurts to bond outdoor electrical devices.
May 20, 2014 | Maax Water Heaters
At electrical connection, from 120 ac on, off switch which remote controll connection terminial ...T1 or T2 does the black hot wire and the white neutral wire connect to ???? manuel does not show
On this unit it does not matter because it is a restive load usually I would go black t1 and white t2 it should be L1 and N always unplug before working on it
Dec 01, 2013 | Rinnai 7.5 Gpm Gas Tankless Water Heater -...
PowerStar AE9.5 isn't working. Bought new. Water lines are hooked up to the correct water lines. The 240V wire coming from the breaker is hooked up as follows: Uncovered copper wire connected to ground,...
The unit will not owrk unless you have 240V ACROSS the black and white wires...if you do not have that coming to the unit then you have a bad breaker...
heatman101
Feb 19, 2011 | Bosch PowerStar AE9.5 AE9.5 Point-of-Use...
I have a ruud oil forced air furnace, but the model # says it is a Rheem ROBC-130. My problem is that the blower motor runs all the time, the furnace will fire and run for about a minute then shut off it...
this is more than a fan control relay . it is a black relay that will appear to have several wires connected to it but those wires connect to the base ,it unplugs , if it is set up for ac it might have 2 relays one toward the front one toward the rear replace the front one first ,,, if on good replace one @ rear should fix if not let me know
Dec 27, 2008 | Water Heaters
Gas furnace cycles on then shuts down
COULD BE A ROLL OUT SWITCH ,OR GAS PRESURE TO HIGH TRIPPING ROLLOUT SWITCH COULD BE A FLAME SENSOR ,TELL ME MORE IF POSSIBLE
Nov 21, 2008 | Water Heaters
Filtrete Thermostat. 7-Day Digital Programmable Thermostat 3M-22 Logo
Top Filtrete Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Filtrete Water Heater Expert? Answer questions, earn points and help others
