Question about Refrigerators
Westinghouse RJ523v, freezer cooling buy not defrosting?
    Scholar:
  • 77 Answers
Most likely going to be the defrost heater element or the defrost thermostat. Both are located behind the false back in the freezer and can be tested with a multimeter (Or just replace both if you don't have one, the parts are not too expensive). I cant recall the heater Ohm rating, but as long as it's not open circuit it is OK.
Although unlikely to be the cause, if you want to double check the control board (If the heater element and thermostat test OK), you can simply use the diagnosis mode on this model.
First, switch fridge off at the power point for at least a few minutes, press the clock button on the display to ensure there is no residual charge in the system.
Second, turn the fridge on and immediately press both "Fridge" and "Freezer" buttons simultaneously.
Move through the test modes by pressing the "Clock" button, when the screen shows "def" the heater should turn on. It will start getting hot and melt any ice, if these parts are working.
Posted on May 04, 2013
5 Suggested Answers
  • 135 Answers
SOURCE: WESTINGHOUSE FREEZER MATE
Check the back bottom freezer wall to see if there is frost on it. If so you have a defrost problem. If the coil dosent defrost it becomes an ice ball and no air can flow. Could be a defrost timer which switches the refrig into the defrost cycle. There is also a heater and thermostat in the system. Shut it off overnight with the doors open to defrost it and get it temporarily running . If it is not frosted up make sure your coil underneath is clean and your cooling motor is running in the back, bottom.
Posted on Jun 13, 2008
  • 119 Answers
SOURCE: Westinghouse model RS663T - not cooling fridge or
IT IS THE DEFROST THERMO STAT REMOVE REAR COVER AND MELT ICE IT IS ROUND SILVER PART
Posted on Jan 31, 2010
  • 4 Answers
SOURCE: westinghouse virtuoso fridge freezer on top has
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Posted on Oct 13, 2010
  • 257 Answers
SOURCE: Hi, I've recently found that my westinghouse
if the back wall of the freezer is iced up the problem is most likely the defrost thermostat.
Posted on May 06, 2011
May 06, 2011 | Westinghouse Refrigerators
Fridge section not getting cold whilst freezer operating as normal.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Westinghouse Refrigerators
My westinghouse refrigerator has stoped working but my freezer is working fine help. Model Bj513V Serial Number 72656346
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 18, 2010 | Westinghouse Microwave Ovens
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
Oct 13, 2010 | Westinghouse Refrigerators
I have a Westinghouse frost free fridge with freezer on top.(RJ340M) Freezer part is working great but the fridge is not performing well at all. Thermostat was my first thought but wouldn't that be...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 23, 2010 | Westinghouse Refrigerators
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Jun 13, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
